Toro Workman 3200 project...anyone have one of these?
/ Toro Workman 3200 project...anyone have one of these? #111
BTW, last week I saw a 4x4 tranny unit listed on Craigslist in the Los Angles area for $900.
David from jax
Seems to be lots of Workmen in SoCal. I am giving all the innards of my spare 4x4 trannie to the buyer.
I see the new gas Workman UTV gets a bigger 1-liter engine.
/ Toro Workman 3200 project...anyone have one of these? #113
Does anyone have any parts for a 2014 Workman HDX Auto 4x4 with a Terra Cab looking for a shift actuator, (that’s the piece on the auto transmission that the shift cable attaches to ) and a full glass door right side !
/ Toro Workman 3200 project...anyone have one of these? #114
Does anyone have any parts, looking for a shift actuator, (that’s the piece on the auto transmission that the shift cable attaches to ) and a full glass door right side !
The year and model of your Workman would make a big difference to what you need.
I purchased 4 and ended up only getting 3 doors to a Toro Workman cab. They are not the same as what is on my Toro Workman (Mauser Cab) but the hardware looks very similar, which probably means it is for a later model than what I have. I sold the cab unit I had that had a full glass passenger door on it.
My plan is to use the window out of one of the doors I bought to make a window in the passenger door. Currently my thoughts are to build another door and install the window to get a little more ventilation in the cab. Door isn't too hard to build, just 1x1 square tubing if I use the hardware from the later doors but right now I don't have time to do that. There just needs to be more ventilation in the cab. My cab has a heater, and if I don't pull the heat, I can just turn the heater fan on and it blows fresh air around the cab. That helps a lot.
David from jax
/ Toro Workman 3200 project...anyone have one of these? #115
Does anyone have any parts for a 2015 Workman HDX Auto , looking for a shift actuator, (that’s the piece on the auto transmission that the shift cable attaches to ) and a full glass door right side !
/ Toro Workman 3200 project...anyone have one of these? #116
David from jax
I edited it thank you !
/ Toro Workman 3200 project...anyone have one of these? #117
I have some Toro parts, tend to acquire them and then sell/trade them off to a buddy in TN. He and I bought 7 parts machines together because he needed a couple parts that were in a "lot" for sale. I made a seriously low offer and ended up having to go after them. Nothing anywhere close to being in this decade.
My buddy is the Toro Workman mechanic, not me. I just find a few deals and go after them.
David from jax
/ Toro Workman 3200 project...anyone have one of these? #118
David from jax
So no 14 HDX parts ?
/ Toro Workman 3200 project...anyone have one of these? #119
Probably not! I am not very familiar with the different models and what fits what. However, I will tell you that Toro doesn't like to reinvent the wheel, and uses a lot of parts that fit several different models.
At some point post a picture of the shift actuator. I won't be able to look at it this weekend, but will try to see if it matches something on one I have. The "auto" part of your description pretty much does away with all of mine because I buy stick shifts behind Mitsubishi engines. Any others are just part of a "lot". I think I have 2 that are HDX labeled. (One has disc brakes that will get used soon!!)
Most have been picked over pretty much, which is why I got them so cheap.
David from jax
2020 ASV RT65 (A60462)
2017 Ford F-250 Pickup Truck, VIN # 1FT7W2B63HED67208 (A61165)
2017 Ford F-250...
Yanmar YT359 (A53317)
Rooster Weathervane (A55853)
Rooster...
2017 Load Trail 3.5 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
2019 Ford F-150 (A60462)
2019 Ford F-150...
