hayden
Elite Member
- Joined
- Sep 23, 2000
- Messages
- 2,524
- Location
- VT
- Tractor
- Kubota L5740 cab + FEL, KX121, KX080, Deere 6120M
Are you looking to directly (or as directly as possible) connect the quick connects to the valve, or would there be hoses between them? In the pictures they seem separated, but maybe you are changing that?
If direct connect, you can get female to female JIC swivels with different sizes on each end. I agree with others that its also worth checking whether the valve end are ORB. They sure look like it, but you thought some were not? If the are, I'd look at removing the ORB to JIC Male, and look at replacing with an ORB to JIC Female that will connect directly to the couplers? Also check the couplers to see if they are actually ORB with JIC fittings attached? Maybe an ORB male to ORB amle will allow a direct connection without all the intermediate adapters.
