Pex Clamp/Ring Question
/ Pex Clamp/Ring Question #1
dieselscout80
Elite Member
South Carolina
New Holland TC45DA
Is there a Pex clamp ring that separates so you can put it on an already installed pipe like a regular hose clamp?
I messed up one crimp and there’s not much pipe left to cut off to redo it with a new crimp ring.
/ Pex Clamp/Ring Question #2
When I was re-plumbing my house a few years ago I screwed up a couple crimps in the process. Was able to (gently) cut the old ring, pry it off, remove the pipe from the fitting and put on a new crimp ring. Dunno how well that would have worked if it'd been on there a while.
I suppose you could get away with a hose clamp, never tried it on pex, but I did have a copper pipe burst a few years earlier and did a temporary repair with some automotive heater hose & hose clamps.
Thanks 😊
However, I’m really wanting a Pex clamp but one that can be installed on the installed line.
/ Pex Clamp/Ring Question #4
Why can’t you take the pipe apart if you’re cutting the old crimp anyway?
I haven’t been able to pull the fitting out without having to cut the pipe off it.
/ Pex Clamp/Ring Question #7
This style you can straighten the small lock tab and unroll it.
Might be a bit tough to get it back together, but I have done it in the past.
These style clamps are popular om European vehicles.
Patrick
/ Pex Clamp/Ring Question #8
I not aware of anything like you're asking for. You can carefully cut the current ring off and take the joint apart and re apply a crimp ring, or cut out a section and splice in another section
The mangled crimp is holding and NOT leaking so I am going to let it ride for now.
If I have to replace it I will cut it out and do a short extension of the cpvc it connects to.
Thanks for the advice and suggestions! 😀
/ Pex Clamp/Ring Question #10
You can use a 5/16 width hose clamp. The problem is the high pressure point discontinuity under the worm gear tightener. This must be blended in some way to get even, leakproof clamping. I have good luck using ~ 10 to 20 wraps of 1/2" teflon tape under the clamp. - - Teflon has an interesting "cold flow" characteristic that favors flow away from extreme pressure locations. It self adjusts toward an even clamp force. Tighten the clamp gently repeatedly for an hour or so til it stabilizes.
/ Pex Clamp/Ring Question #11
Good point.
Or get one of the styles of clamp that are continuous under the screw. Personally, I have had too many issues with "standard" screw hose clamps.
All the best, Peter
/ Pex Clamp/Ring Question #12
Good point.
All the best, Peter
The continuous type are great if you have the option of separating and remaking the joint. Not so much when you have to open up a small clamp to put around an unbroken line.
- A little work on the worm screw hose clamps pays off in sensitive situations; de burr the overlap tang, lube the mechanism (Militec is best) so side thrust tightening the band is limited. Before assembling preform the clamp to the subject diameter by tightening on a mandrel once or twice, minimize excessive band length and curl the end to easily enter the screw. The "rigid" region comprising the mechanism will hold the appropriate curve pretty well when you have to open up the clamp to get it around the tube.
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2016 Chevrolet Silverado 3500 Auto Crane Service Crane Truck (A64194)
2016 Chevrolet...
2022 EZ-GO ELITE...
Year: 2014 Make: Chevrolet Model: Equinox Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 134,356 (A64557)
Year: 2014 Make...
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
2005 GENIE S-45 TELESCOPIC BOOM LIFT (A65053)
2005 GENIE S-45...
