Shawn T. W.
- Joined
- Jul 14, 2025
- Messages
- 2,056
- Location
- SW Missouri Ozarks
- Tractor
- Massey Ferguson GC 1725 MB - Kubota L5030 - John Deere Z960M
I bought this 2018 1500 back in October of '21, not much to choose from back then, but it's mine now!
I was planning on doing a few things to it when I got it, but ended up finding this current place 2 weeks later, and moved from Arizona ... Just one thing after another ...
Yesterday I got it up on 4 jack stands and removed the tires, scrubbed them, after they dried I applied a tire dressing that is supposed to reduce ozone degradation, I did both the inside and outside, I'm a long distance truck driver and leave my pickup at my company's terminal for weeks on end (I don't really go for the shiny tire look!)... Then started on a long overdue brake fluid flush ...
Unfortunately I only got one wheel done before running out of the quart! (Since I already had it in the air, and more things to do with the wheels off, I decided to get back to it later!)
Then I added 1.25" wheel spacers so I have the option of putting chains on ... Used the Orange thread locker, the gel doesn't go very far!
This morning I started on adding a 2" front leveling kit ... I was looking for a small lift "kit" but generally they start at 4" and I didn't want that much ... So I got the leveling kit, plus found a 1.5" rear lift ... I want to keep the almost stock "rake" with the tail higher than the front when empty.
Since I added wheel spacers, I decided to install small smooth fender flares.
When I got the truck it had black plastic wheel covers, I lost one, so I took off the other one on that side, so that side would match, but really don't like the look of the factory aluminum rims, and I liked the black and white theme I had going on, so I had to buy a four pack, didn't realize that they are a dull faded black, but they are on one side, I have the shiny black ones which I like better on the other side ... Then I rotated the tires since they were already off ...
I'm glad I didn't go with a 4" lift, this is plenty tall enough for me, probably will add a set of gramps steps!
Now I have room for chains!
I have a dentist appointment in the morning, so I'll pick up a couple more quarts of brake fluid and finish that job tomorrow ...
