Anyone DIY dye their hydro oil?
/ Anyone DIY dye their hydro oil? #42
I have used the John Deere dye and it works great and helps a lot. Ironically, when I went to my John Deere dealer to get some, they had never heard of it, so they looked it up and ordered it for me.
either rough up your dip stick or paint it and you will be able to see the level better. then you won't have to add die every time you change oil.
I usually have better luck with the smooth shiny side of a dispstick, when oil is too clean and clear to easily see. On the hatched area, it's just another reflection, but the wetted line is easy to spot on a smooth shiny side of the stick.
The trouble here is that the dipstick has the large stamp forged XXX's on both sides, deep relief about 1/16" high. There is no "smooth side" like a normal sheetmetal stick with cross-hatching on only one side.
I just bought this, one of the few cases where the Deere OEM version is the cheapest one to appear, when searching "hydraulic oil dye":
/ Anyone DIY dye their hydro oil? #44
This is my lubricant dye substitute.
Works on all hard to see oil levels 😁
My eyesight is fine, this is an issue of trying to spot glossy clear low-viscosity fluid on a glossy metal stick covered in stamped X's. Like finding where a painter stopped one day and picked up the next, with the same color and sheen.
/ Anyone DIY dye their hydro oil? #46
Doesn't diesel oil start changing color pretty early on due to the soot over time or are they so clean now that doesn't occur as soon?
I know my 04 Dodge Cummins cranking 600hp 1200tq out the rear wheels doesn't need an dye LOL
/ Anyone DIY dye their hydro oil? #47
Those with a dip stick can take a clean shop rag or paper towel, which hopefully you have with you when checking, wipe the stick, dip it, then lay it down flat on, or squeeze it with, the paper towel or shop rag, and look at the stain. Bit of a pain.
Those with a sight glass might take a small flashlight and try shining it at various angles.
I'd try those things first before adding dye to an expensive hydro.
/ Anyone DIY dye their hydro oil? #48
The hydro oil in my 2019 tractor remains so clear and clean, that I almost can't see it on the heavily-hashed dipstick on my 3033r. I see some run hydro oil (probaby ATF) with red dye in it, and I'm wondering, does anyone put some dye in their own hydro oil to make visibility at least a little better?
Instead of adding dye to the hydraulic fluid, I blued the bottom two inches of the shiny dipstick so that clear oil would show up better. Simple improvement.
rScotty
/ Anyone DIY dye their hydro oil? #49
I use the JD dye in my Kubota. Mine has a dipstick too but was still hard to see. I also figured that if I ever had a leak, this would help me see it before I ran too low. I use my tractor in the woods a bunch and felt it would be a good idea.
/ Anyone DIY dye their hydro oil? #50
as mentioned even a dipstick can be hard to read w/clear fluid. i gun blue dyed the dipstick. in addition, when reading, i invert it & hold to sunlight, giving me an accurate reading. each has his own method
KJ K2223 23'x22' Metal Shed (A60463)
KJ K2223 23'x22'...
2011 AUXILIARY POWER UNIT (A60736)
2011 AUXILIARY...
2009 CAROLINA  16FT EQUIPMENT TRAILER (A58018)
2009 CAROLINA...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
1985 CADILLAC SEVILLE (A60736)
1985 CADILLAC...
2017 Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A60352)
2017 Gravely...
