Anyone DIY dye their hydro oil?
   / Anyone DIY dye their hydro oil? #51
It’s easier to see on a black zip tie. Just kink one at the right spot to match your dip stick.
   / Anyone DIY dye their hydro oil? #52
The hydro oil in my 2019 tractor remains so clear and clean, that I almost can't see it on the heavily-hashed dipstick on my 3033r. I see some run hydro oil (probaby ATF) with red dye in it, and I'm wondering, does anyone put some dye in their own hydro oil to make visibility at least a little better?
Thanks for the question. It made me remember that I used to press some dip stick or other against a paper towel. The towel must have been the cheap brown kind because the length of the stain was easy to see.
   / Anyone DIY dye their hydro oil? #53
At the shop, we sprinkle baby powder on the end of the dip stick, then recheck the level. This works great for checking the engine oil or hydraulic fluid when a dip stick is involved,
   / Anyone DIY dye their hydro oil? #54
Doesn't diesel oil start changing color pretty early on due to the soot over time or are they so clean now that doesn't occur as soon?
I know my 04 Dodge Cummins cranking 600hp 1200tq out the rear wheels doesn't need an dye LOL
This is in the transmission, fluid should remain clear to translucent ...
   / Anyone DIY dye their hydro oil? #55
Mine has a dipstick, too! But both sides are cross-hatched one at the full mark 's no smooth side for viewing the "wetted" line. Just about impossible to see the fluid without walking out to daylight with the dipstick in-hand.
Mine too. I drilled a few small holes in the dipstick one at full and one at the low and one between. Pull the stick out if there is no oil in any hole you have an idea of the level.
   / Anyone DIY dye their hydro oil? #56
I found a dye at the local farm supply store, in the tractor stuff. It is a slime green color and is also UV Fluorescent. So, if needed, I can use a UV flashlight to check of leakage. Sorry can't remember who makes it. I have a bottle on the shelf in the garage, but I'm traveling for the next few months.
   / Anyone DIY dye their hydro oil? #57
Local O'Rilleys auto parts has "hydraulic leak detection dye"....
This! If you are gonna add dye, might as well use fluorescent tracking dye for oil. That way you can use a UV flashlight to detect even the smallest leak (a 365 Nm wavelength light works best). As an aside, the UV light is handy for other stuff too.
   / Anyone DIY dye their hydro oil? #58
For those with sight-glasses, attach a little piece of white tape (e.g. bandage tape) to the back side of the sight glass. It will make viewing the oil level super easy with or without dye. I have both and can see the level at a glance from quite a distance
   / Anyone DIY dye their hydro oil? #59
The green stuff I found, is quite bright even in the day light. So, green leaks show pretty well even in the full sun.
   / Anyone DIY dye their hydro oil? #60
Talc is an exceptionally mild abrasive. Apparently a Mohs hardness of 1.0 which is significantly less than steel, but could come close to some babbitt.
The amount you're getting in is probably less than a bit of dust that inevitably gets in somewhere. Anyway, I don't know if I'd put it in my engine, but it may not cause any detectable damage either.
KUBOTA M955 DUAL SPEED TRACTOR (A57192)
KUBOTA M955 DUAL...
2019 RBR Venturi 380 (A55301)
2019 RBR Venturi...
1994 International 3800 Bus (A55852)
1994 International...
2023 Bobcat T66 Two Speed Compact Track Loader Skid Steer (A55851)
2023 Bobcat T66...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A55315)
Galvanized...
2008 Ford F-450 Crew Cab Service Truck (A55973)
2008 Ford F-450...
