Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions?
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #21
The blade came with a hydraulic gauge wheel, but it sits back about 3-4ft behind the blade. It didn't seem to work very well with my roller coaster roads, but then again I was new to tractoring back then. I could see gauge wheels that are right next to the blade working better, but that's a lot more of a project than fitting a pipe to the blade.
^^^Very nice blade. You should be able to straighten out your "roller coaster" roads while plowing snow with that thing. Many of us don't plow unless the ground is froze. We just drive on the snow to make a packed down layer that allows the plow to ride on. If you rarely freeze up, that would be a mess all winter long....good luck.
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #22
It wouldn't take much to move the pivot for the wheel to right behind the blade and better mimic a road grader.
That would largely solve the roller coaster issue, but would make it a chore to turn the blade around since the wheel would be in the way.
Without seeing that setup in person it's hard to tell if making a new (pivoting/liftable) mount or make the wheel's pivot able to turn up or sideways would be the easiest.
Also, a single tire is far from ideal on many, if not most, surfaces. Learned that real quick after making such a setup for my equally heavy blade. So 15 years later I still just go slowly on my undulating driveway, while raising and lowering the loader mounted and rear blades as needed.
Both have skids, letting me know when one blade, or one side of it, is too low and has reached gravel. It took a couple of winters to get better at it, but once in tune with the concept very little gravel has been lost.
I'm a huge fan of having wheels on blades, and one of these years I hope to put one at each end of my blade for winter use, bolted on. Then the rear blade should pretty much take care of itself and I could concentrate on the front one.
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #23
I made brackets to hold snowplow shoes for when the ground is soft.
I had these on a plow once. They dug in like crazy. Took them off and threw them aside. There really mostly for pavement.
The real questions is if the ground is that soft do you really even need to touch the ground with the plow?
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #24
There’s no need to do anything to the blade. Just turn it around so the cutting edge faces the rear and drive forward. It will skim the snow off the road without digging in.
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #25
Great idea, however some plow set ups you can't do that with the plow let alone cutting edge. Over the years I think I've gotten good at cutting a slit in plow using a straight edge and plasma cutter and doing the easiest thing just welding it to cutting edge. Keeping in mind plows are strictly used for snow removal on gravel drive and parking areas on lawn.
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #26
^^Correct, if we are talking muddy ground like the OP has, the shoes will just dig grooves.
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #27
That doesn't work all that well with the blades the OP and I have, at least not when the snow is wet.
Then it often gets stuck on all the stuff on the back of the blade, clumps up, and can even make ruts into the gravel. For me that means lifting the blade to get past the pile, then back up and push that snow off to the side.
Not a big deal with a fully hydraulic 3-way blade with offset, but it still gets old if it happens every 50 feet or so. Not that I think a pipe on the cutting edge is the ideal solution, or I would've tried it.
There are often times when I need the blade to cut into hardpacked snow and ice, and wish it weighed more than 1,600 lbs. That could lead to a lot of unbolting and then reinstalling a pipe.
But I might still try it on a smaller blade, used on a smaller tractor, for times when there's not much snow to speak of.
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #28
I have never encountered the issue that you have described. The reverse blade works well for me.
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #29
And I suspect I know why.
Looked at property near Edgewood last week, then checked the climate around there...you don't get any snow. Well, compared to here you don't.
I even made a list of things I wouldn't need if moving there, most of it snow removal related.
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #30
We have had over 3’ of snow in one storm, many 18” and typically 12” storms. I don’t know who told you that we don’t get snow. We do have some open winters, but certainly do get slammed by heavy storms when the Pacific fronts move in. We also get wrap around winter fronts from the Rocky Mountain front range. Your sources of information are absolutely wrong and I have lived here 21 years.
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #31
Wow, that's nice!
I looked it up on some sort of "average temp/rain/snow" site called Weather Spark. Lots of fancy charts and curves.
If you check it out, maybe they're wrong about how hot it gets, too. That's what scared me away.
Thanks, I can't wait to get this WR Long kit so I can adjust most everything on this blade from inside the cab.
Last year we got 20 inches of snow over a couple of days. It was wet and heavy and started to melt in the afternoons. I plowed it twice with the rear blade, leaving about 1-3". It got packed down with traffic, but it's not like in colder areas where the packed snow stays as packed snow. Here, with the warmer temps and the sun, it will start to melt and re-freeze into ice. So my roads turn into ice covered roller coasters.
I've welded pipes to cutting edge for plowing snow, despite what others say and think if you have access to a plasma cutter that works it's easy, clamp pipe in a stick of angle iron preferably as long or longer than pipe, use edge of angle as a straight edge dragging torch along edge, loosen clamps rotate pipe slightly and cut adjacent groove. Learned the harder way have plasma cutter consumables on hand or your going to be using a grinder to finish cut. Lol
That was my plan, but I talked to a fabricator about it this morning and he told me it's not as simple as that. According to him, pipe has internal stressors (due to manufacturing) that will warp the pipe when a slit is cut along the entire length.
If the shoes dug in, I think the round pipe will dig in worse. I'd look into making longer (like 12") skids mounted on the side.
That is a thought, though at that point I'd just figure out a way to mount a couple of wheels.
I did make some huge (12" dia each) skids for the blade last year, but they just dug in.
AI....J55 steel is not a "tool steel" but rather a low-grade casing and tubing steel specified by the American Petroleum Institute (API) under the API 5CT standard. It's primarily used in the oil and gas industry for shallow wells due to its low cost and wide application range, with a minimum yield strength of 379 MPa (55,000 psi) and a minimum tensile strength of 517 MPa (75,000 psi).
OK, thanks for correction. The guy selling it told me it was "tool grade" hardened steel. I guess for $35 I can't complain though!
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #36
I used a piece of PVC conduit on my bucket edge to help a neighbor with some stone he had delivered on asphalt. Did a nice job of sliding on asphalt without gouging it!
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #37
Maybe but the Straight cutting edge on plow will probably take a bow out especially if you tack weld it first as you straighten the pipe out along cutting edge. Anyways never had a problem yet however I definitely wouldn't consider myself a professional fab or welder so take my free online experiences as such. I will say if I needed the cutting edge to use to grade dirt or gravel I probably would go with those that suggest welding angle on pipe laying out drilling and thru bolting to existing cutting edge holes so pipe is removable when and if a cutting edge is needed. However never in my tractor and atv snow plowing experiences did I wish my plows cutting edge was there. I kind of learned the hard wayy when I got my first compact kubota tractor they Aren't bulldozers. 😂
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #38
Wow, that's nice!
The hottest month in Edgewood is June, where temperatures can get into the mid 90s. In July -August temperatures fluctuate between the mid 70-80s depending on whether or not it has rained that day. Now we are in the low 70s, headed for the 60s soon. It’s not really a hot climate; even Albuquerque only get an average of 4-5 days per year when they might break 100 degrees. Keep in mind that Edgewood is over 6,500’ elevation and where I live is 6,950’.
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #39
Being that the OP has a FEL, I wonder if triple Edge Tamers might work for some conditions? :unsure:
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #40
So this a pretty elaborate back blade? You'd think the hydraulic top link would angle the cutting edge enough so it won't cut into the road under most conditions?
832798 (A61166)
832798 (A61166)
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
KOMATSU WA270 (A58214)
2015 LAND ROVER RANGE ROVER EVOQUE (A60736)
2015 LAND ROVER...
2008 DOOSAN G25 GENERATOR (A58214)
2008 DOOSAN G25...
