Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions?
   / Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #21
The blade came with a hydraulic gauge wheel, but it sits back about 3-4ft behind the blade. It didn't seem to work very well with my roller coaster roads, but then again I was new to tractoring back then. I could see gauge wheels that are right next to the blade working better, but that's a lot more of a project than fitting a pipe to the blade.
^^^Very nice blade. You should be able to straighten out your "roller coaster" roads while plowing snow with that thing. Many of us don't plow unless the ground is froze. We just drive on the snow to make a packed down layer that allows the plow to ride on. If you rarely freeze up, that would be a mess all winter long....good luck.
   / Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #22
It wouldn't take much to move the pivot for the wheel to right behind the blade and better mimic a road grader.
That would largely solve the roller coaster issue, but would make it a chore to turn the blade around since the wheel would be in the way.
Without seeing that setup in person it's hard to tell if making a new (pivoting/liftable) mount or make the wheel's pivot able to turn up or sideways would be the easiest.
Also, a single tire is far from ideal on many, if not most, surfaces. Learned that real quick after making such a setup for my equally heavy blade. So 15 years later I still just go slowly on my undulating driveway, while raising and lowering the loader mounted and rear blades as needed.
Both have skids, letting me know when one blade, or one side of it, is too low and has reached gravel. It took a couple of winters to get better at it, but once in tune with the concept very little gravel has been lost.
I'm a huge fan of having wheels on blades, and one of these years I hope to put one at each end of my blade for winter use, bolted on. Then the rear blade should pretty much take care of itself and I could concentrate on the front one.
   / Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #23
I made brackets to hold snowplow shoes for when the ground is soft.
I had these on a plow once. They dug in like crazy. Took them off and threw them aside. There really mostly for pavement.
The real questions is if the ground is that soft do you really even need to touch the ground with the plow?
   / Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #24
There’s no need to do anything to the blade. Just turn it around so the cutting edge faces the rear and drive forward. It will skim the snow off the road without digging in.
   / Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #25
Great idea, however some plow set ups you can't do that with the plow let alone cutting edge. Over the years I think I've gotten good at cutting a slit in plow using a straight edge and plasma cutter and doing the easiest thing just welding it to cutting edge. Keeping in mind plows are strictly used for snow removal on gravel drive and parking areas on lawn.
   / Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #26
^^Correct, if we are talking muddy ground like the OP has, the shoes will just dig grooves.
   / Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #27
That doesn't work all that well with the blades the OP and I have, at least not when the snow is wet.
Then it often gets stuck on all the stuff on the back of the blade, clumps up, and can even make ruts into the gravel. For me that means lifting the blade to get past the pile, then back up and push that snow off to the side.
Not a big deal with a fully hydraulic 3-way blade with offset, but it still gets old if it happens every 50 feet or so. Not that I think a pipe on the cutting edge is the ideal solution, or I would've tried it.
There are often times when I need the blade to cut into hardpacked snow and ice, and wish it weighed more than 1,600 lbs. That could lead to a lot of unbolting and then reinstalling a pipe.
But I might still try it on a smaller blade, used on a smaller tractor, for times when there's not much snow to speak of.
   / Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #28
I have never encountered the issue that you have described. The reverse blade works well for me.
   / Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #29
And I suspect I know why.
Looked at property near Edgewood last week, then checked the climate around there...you don't get any snow. Well, compared to here you don't.
I even made a list of things I wouldn't need if moving there, most of it snow removal related.
   / Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #30
We have had over 3’ of snow in one storm, many 18” and typically 12” storms. I don’t know who told you that we don’t get snow. We do have some open winters, but certainly do get slammed by heavy storms when the Pacific fronts move in. We also get wrap around winter fronts from the Rocky Mountain front range. Your sources of information are absolutely wrong and I have lived here 21 years.
2008 Kenworth T800 Semi Tractor, VIN: 1NKDX4TX68R235070, Day Cab, Cummins ISX-600 Turbo Diesel (A59076)
2008 Kenworth T800...
Welding machine (A56857)
Welding machine...
UNUSED FUTURE...
2012 BMW 328i Coupe (A56859)
2012 BMW 328i...
2017 JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
2017 JOHN DEERE...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 (A55787)
2016 New Holland...
