Stabil in the mix?
/ Stabil in the mix? #21
About a decade ago. I gave Stabil a try. I put it in 5 different engines that fall. 18 months later I had lost all 5 engines...he lost an entire fleet of equipment.
I'm not pretending it's anything great, or that it lives up to its marketing hype. But the reality is that any product with a 100% failure rate would not be at the top of the market, in terms of sales, especially after 20+ years on the shelves.
Stabil may be crap, I certainly don't use it anymore. But I have to question your story, just the same. No one is losing "entire fleets of equipment", or having every engine into which they install it fail, without some other undisclosed factors in the mix.
And I have used Stabil in the past, many times in my own portable generators, with no issues. I switched to StarTron several years ago, because it's supposed to be better, but I've honestly never had any issue with either.
/ Stabil in the mix? #22
I guess I'm the lucky one with StaBil, the storage one, as I've probably been using it for almost 20 years now on everything all year round. Pressure washers, chainsaws, old truck that sits more than it drives, generator, mowers, etc. I do use a gas station that is fairly busy so in theory has fresher gas than a mom and pop store off the beaten track. I have never drained or run dry any of my equipment. The oldest equipment is around 20 years old and the newest is around 5 years old.
The generator is the only one I will drain/refill the gas on if I don't use the tank up within 2 years, I will just mix it with some new gas on the mower or something that will use all the gas up fairly soon.
I now have 4-14 gal tanks that I use, 2 for gas and 2 for diesel. The thinking is that I won't have one big tank sitting half empty half the time and don't have to refill the 5 gal tanks every few days. I use the storage version as I don't know how much gas I'll use in a year, I might refill the 14 gal tanks up 3 or 4 times a year one year and maybe once the next year.
But then I never used any treatment the years before and never had a problem either, I just started using it because of all the horror stories and figured better safe than sorry.
/ Stabil in the mix? #23
I’ve never had a problem with Stabil. I’ve only had a couple of small engines with fuel problems. Both cases had definite fuel issues. Both cases low fuel levels in a gas tank stored for more than 6 months with ethanol fuel.
/ Stabil in the mix? #24
Red Sta-bil is no good. I have been there. It only works on machines that don't move. I know the pain of trying to start a chainsaw after using red Sta-bil and finding out I have been swindled.
You want Biobor EB.
The other day I picked up a saw after maybe 7 months of down time, full of old gas. I cringed because I fully expected to have to rebuild the carb. My fault. It fired right up and ran perfectly.
Biobor EB, Red Armor, and ethanol-free gas. I was astonished. In my climate, this is like a miracle. Before I started using this combination, I would have expected maybe 6 weeks of protection.
I'm not positive, but it seems like Biobor EB plus Red Armor is much better than Biobor alone. I have to put oil in my fuel anyway, so might as well use something arborists love instead of saving 10 cents on cheap stuff.
/ Stabil in the mix? #25
You want Biobor EB.
IMHO it's your E-free gas doing that for ya.
All I use on OPE and boat. Never a issue with it.
How to tell your Efree is really efree and no percentage of ethanol in it. It will look like this after a quick test.
I do this ob every batch I buy.
Today's prices since going up this year even higher is now 4.79 a gal.
/ Stabil in the mix? #26
Then this is a test with 10% in it to show how to tell difference.
/ Stabil in the mix? #28
What's the item in the bottom of the glass? Looks like mouse poop. :p
Old pilots test way back when didnt have their kit.
Water soluble food coloring.
Food coloring drop. If E-free it don’t start to dissolve. Stays solid beads after stirring.
If it has ethanol in it it starts to dissolve after stirring etc.
/ Stabil in the mix? #29
Be sure to pick some color besides blue or red, since those are already avgas colors....
/ Stabil in the mix? #30
I dont run av gas. So no worries here.
I tried it and did not care for it myself. Friend used to use it and get by the drums. All he runs at one time.
No clue if still running it since he retired from airport.
/ Stabil in the mix? #31
Up to 03 or so. My E-free was yellow like diesel. I used to have to make sure I didnt get wrong one before mixing.
/ Stabil in the mix? #32
Now Efree is this from same pump since 04.
/ Stabil in the mix? #33
It's not the gas. In my climate, a saw will clog just fine with ethanol-free gas. It just takes longer.
Most people don't know this, but ethanol is not the only problem with modern gas.
/ Stabil in the mix? #34
I've been spending the money on pre-mixed fuel. Yeah, it's not cheap, but everything starts quickly. I only use about a gallon and a half each year, most of it in the fall and early winter, so it works for me. I do use Startron in all the 4 stroke stuff, though.
/ Stabil in the mix? #35
90 octane "REC GAS" e-free is 3.49 at local Circle K. Sometimes they run out and I go to a BP station that has 89 e-free. They are usually .20-.30 higher
/ Stabil in the mix? #36
Must be nice. 4.79 here up .30 from last year.
/ Stabil in the mix? #37
Just paid 4.59 for e free 90
/ Stabil in the mix? #38
View attachment 4137846View attachment 4137847
How do you tell if it's e-free when at the pump to buy? I thought of this today as I was filling up my truck at Chevron, looked all over the pump and saw nothing but the octane ratings. The average guy just doesn't have much choice these days. I know that aviation gas is supposed to be e-free but it's hard to find where to buy that too? (as an average joe buyer). Just curious.
/ Stabil in the mix? #39
Old pic when was cheaper years back.
Our places use separate pump and hose.
Can search here for reported Efree stations. Pure-gas.org - ethanol-free gasoline in the U.S. and Canada
porta potty (A68842)
2022 JCB Fastrac 4220 217HP 4WD Agricultural Tractor (A66734)
2022 JCB Fastrac...
2018 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A65057)
2018 CHEVROLET...
2006 HEIL MC407 (A67714)
2006 HEIL MC407...
Tropic Trailer 18ft T/A Flatbed Equipment Trailer (A64553)
Tropic Trailer...
2019 Chevrolet Tahoe SUV (A66738)
2019 Chevrolet...
