Radiator replacement or just fix it?
/ Radiator replacement or just fix it? #1
FMFProperties
Ben Wheeler, Texas
Branson 4520C & Massey 1533
Anyone know if there's an aftermarket radiator for a Branson 4520-C that doesn't cost $700 ?? I took it in for a cleaning and they told me it has a hairline crack on the plastic top. In my experience JBWeld fixes everything I've used it on, including hard to reach copper water pipes in my house and no leaks, but the guy told me that the radiator plastic expands due to heat & pressure so JBWeld wouldn't work.
Part # EA00003972
/ Radiator replacement or just fix it? #2
Anyone know if there's an aftermarket radiator for a Branson 4520-C that doesn't cost $700 ?? I took it in for a cleaning while they're repairing the head and they told me it has a hairline crack on the plastic top. In my experience JBWeld fixes everything I've used it on, including hard to reach copper water pipes in my house and no leaks, but the guy told me that the radiator plastic expands due to heat & pressure so JBWeld wouldn't work.
Part # EA00003972
Some years ago, I bought an OEM radiator for my 3520 from Dave's Tractor, it was $390+tax+ship.
No idea if they've about doubled since then, but I'd try calling around.
/ Radiator replacement or just fix it? #4
Depending upon how much gold your dealer and Branson may think is in that radiator a "custom" one may be a better deal;
Thanks. I contacted a few sellers on eBay and they've all replied not having the size needed and the one that did have the correct core size had the water outlets a lot bigger than needed so we then get into having to have someone local cut and weld new ones to modify it, and being aluminum, that just increases the price exponentially to where it's just faster to buy the expensive OEM radiator.
I sent them a message requesting a quote. Thanks.
UPDATE: JBWeld worked great.
EZ Go TXT Golf Cart (A61166)
EZ Go TXT Golf...
(3) Tires (A65640)
(3) Tires (A65640)
Kubota V1505-T Turbo Diesel Industrial Engine  Pump Takeout (A63689)
Kubota V1505-T...
2018 Case 650M OROPS Dozer (A62679)
2018 Case 650M...
3pt Hitch Receiver  (A62679)
3pt Hitch Receiver...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
