I'll just have water
/ I'll just have water #221
I used to see teachers/college professors wearing jackets like that, almost never in the business world.
My English Teacher always and 2 of the engineers I work with the same… all were much older.
I just grab it to have in Germany and Austria…
When you wear something ripped you can always say it just haloed… :)
/ I'll just have water #222
I was think phase converter as this is how I run my Bridgeport Mill.
Yep. But they're less common today than 20 years ago, the electronic solutions having gotten better and cheaper. And those still going the rotary route are looking for mostly 900 RPM motors (very quiet) or something old and unique looking. This was a generic early-2000's 1750 Baldor, which was quiet but not a particularly enormous rotating mass, and nothing very special looking.
/ I'll just have water #223
I’m using an old 1hp for rotary phase converter without problem since about 1982 for the mill…
/ I'll just have water #225
I hated those iron-on patches too. Not only were they stiff, but they didn't stick very well either. A few washings, and they'd already started to peel off around the edges. :mad:
Would this have been in the late 60s/early 70s? It seemed a fashion fad for a couple years to do away with pockets in men's pants, or only put in one or two, that were often as not too small to fit a wallet in. 🤬
Give me cargo pants any day of the week!
I'm wearing mostly cargo pants now but have a problem with the pocket on my thigh getting caught on Kitchen cupboard knobs. Doesn't happen too often but it's quite a shock when it does. I'm worried about ripping off a door.
/ I'll just have water #226
It's amazing how coordinated your body is and how close you come to so many things without ever realizing it.
I first learned this when I got my first pager and wore it on my belt. Constantly bumping it into stuff that I never hit before, but it was only 1" thick.
/ I'll just have water #228
Don't have the room for an extra bidet seat but the ones that attach to the toilet have plenty of pressure.
That is what I have, and it has plenty of pressure, with warm water to boot. Can also set the seat to heat up. Of course, it is an electric model to do those things, including a fanny fan for after the rinse cycle. Oh, modern luxury 🤩
I decided on electric vs. not electric for the heated water jet. I figured it's cheaper to go that route than to repair the bathroom ceiling, which would be needed when freezing cold water hits the buns, sending the sitter through the rafters. 🙀
Same here.
I needed to have an FM radio with me at work for about 2 years. I had a heavy leather swinging holster for it, that threaded through my belt.
The problem was that the holster was tougher than the radio. I busted the radio case just walking into things.
Cops must have a terrible time walking in congested areas with their duty belt.
/ I'll just have water #232
I was on call 24/7 for thirty years and kept a pager even when cell phones came in due to the cost of air time. It took the better part of a year to realize I didn't need it anymore when I noticed it wasn't on my hip.
/ I'll just have water #234
Lever-style door handles always seem to get me. Catch a belt loop on them.
/ I'll just have water #235
I have in floor registers and in the winter my lounge pants catch on them while walking over them. Darn near fall down every time. I probably should do something about it before I break a hip. :LOL:
/ I'll just have water #236
The largest part of our house was built in two phases, 1730’s and 1770’s. Most of the oldest Suffolk thumb latches were replaced with rim locks in an 1820’s renovation, but a few still remain which we use dozens of times every day.
Between the big hook style catches on the door jambs, the drop bar that sticks out from the edge of the door, the lift/pull on one side of the door and the thumb latches itself on the other, it’s basically impossible to walk anywhere near one of those things without catching some article of clothing on them. I lost quite a few belt loops, until I developed the habit of giving them a wider birth when running around the house.
/ I'll just have water #237
I forgo garbage service in lieu of dropping it in the dumpster at work, likewise I fill gallon jugs of water at work for drinking at home. Those 2 things combined are probably saving me about $1000/year. There are many others like grinding our own meat, buying in bulk, paying annually rather than monthly etc.
Every once in awhile I am amazed by someone's cheapness.
Damn man...I bet you steal the toilet paper, or highly considered it.
/ I'll just have water #238
Seriously, a guy where I worked used to steal toilet paper.
/ I'll just have water #240
I've worked for the same owner for over 33 years. I've never stolen anything and never would. He knows I haul water and use his dumpster. As I said before, it's about a $1000 saving per year and maybe $15000 over the past 33. Every little bit helps the bottom line.
2008 Freightliner Allegro Bay Class A Motorhome (A61574)
2008 Freightliner...
SURE FIRE 5.3GPM LIQUID FERTILIZER UNIT TOWER (A64278)
SURE FIRE 5.3GPM...
3269 (A63117)
3269 (A63117)
2017 Ford Taurus Sedan (A64557)
2017 Ford Taurus...
2000 International 4700 Altec AM655 55ft. Bucket Truck (A64194)
2000 International...
2004 Harmon Steel Barrel Asphalt T/A Tanker Trailer (A64194)
2004 Harmon Steel...
