SSQA Snow/dirt plow blades
/ SSQA Snow/dirt plow blades #1
rScotty
Super Member
Rural mountains - Colorado
Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
Does anyone use an SSQA Snow & Dirt plow blade on a larger utility tractor?
I was wondering about fitting one to our Kubota M59 to maintain an awkward sloped driveway that can turn icy in the winter.
The blade would have to tilt as well as angle, and probably require some sort of shoes or runners.
Any information or hints appreciated.
rScotty
/ SSQA Snow/dirt plow blades #2
There are lots of examples and pics in various threads showing SSQA snow plow setups. I have one on a 57 HP Kubota. It's a standard Meyer plow pinned to a SSQA plate and angled using 3rd function valve. Seems like that would fit the bill.
But it's NOT a DIRT blade. Not sure what a "snow/dirt blade" would be.
/ SSQA Snow/dirt plow blades #3
rScotty
The folks at good works tractors are having a closeout sale on HLA SSQA snow plow blades with manual angle adjustment but no tilt.
These snowplows have skid shoes and the hydraulic angle adjustment option can be purchased for extra cost.
SSQA 6 way dozer blades can start at almost $4,000.00
Not really looking for dual purpose. It will be used in the snow and maybe a bit on rough ice.
I have no plans to use our good tractor like a bulldozer in the dirt.
I just mentioned snow+dirt because the one I saw years ago was advertised that way.
What I'm wondering about is how well does it work? Does it need skids? What are the downsides? Can you see the edge? Part of what I need to do is work around bushes and trees, and scrape down to ice if the snow is compacted.
I don't see many tractors equipped with a SSQA blade and wondered why.
/ SSQA Snow/dirt plow blades #5
I have mine set up just like a truck mount. It works just as good as a truck plow would, with the advantage of not needing to maintain a separate truck or SUV for it to be mounted on. It's also super easy to attach or drop -- just drop the plate and detach the quick-couplers. It's important to mount it to that the A-frame hangs from a chain and doesn't let the plow carry the weight of your loader and tractor.
I don't use shoes on mine, but I have some. People have different opinions on those. I find that if I set the angle-of-attack low enough that mine doesn't really dig in MUCH. I still do push some gravel into the grass and have to clean it up in the spring.
The only downside is that it sticks out pretty far. You could get your self pushed sideways if you drove too fast and pushed into something big. I don't have problems but my terrain isn't as steep as what yours sounds like. You can't drive it miles away to help someone else get plowed out, but that's actually probably a "plus". The markers that stand up on the end of the blade make it easy to tell where you're at and I can see the snow roll out of the end of mine just by looking over the front tire.
It's easy to get up close to bushes etc. and drop the blade to back-drag or push on past them. I think you can see much better than when using the same plow on a truck.
In my opinion, the best setup is having a rear-mounted snowblower too. You can plow most of the time, but if it gets too deep or you run out of places to pile it, you can just turn around and make it disappear.
Whatever you do, don't get a snowplow that's solidly welded to the SSQA plate and doesn't float. I bought one like that from a guy and broke it the first day. You can't tell how much weight and downpressure you're putting on the plow. It needs to be setup just like a truck mounted plow -- pinned at the rear so it can float up and down and then you raise or lower with a chain attached near the front of the A-frame.
Hope this answers your questions. We've posted a lot of pics of different setups over the last few years. I'm sure you can find the threads.
/ SSQA Snow/dirt plow blades #6
I plow with an HLA 2000 7' SSQA blade, and it works great. I do around 15-20 long residential drives in my immediate area.
I can see both sides of the blade from the cab, and it's on the heavy side at 535 lbs. It scrapes packed snow as good as any other blade will, plus I can put the tractor weight on it if necessary. It gets a little squirrelly when the front end weight is on the blade though... no traction / steering.
I run it 99% of the time with an UHMW Polyethylene edge and fabricated side wings.
/ SSQA Snow/dirt plow blades #7
This is why some plows have the ability float independently of the loader. That way the loader adds weight to the front tires to aid in traction.
/ SSQA Snow/dirt plow blades #8
I didn't invent the "underslung mount" but it does the trick. Here's info from mine back in early 2019:
/ SSQA Snow/dirt plow blades #9
The reason you do not see many of them is because of the mounting system on a front end loader of a farm tractor; one small impact can cause a massive twisting/racking of the loader arms, where an under frame mount to the rear axle and engine cradle provide more structural strength for the underslung plow frame.
/ SSQA Snow/dirt plow blades #10
There is SIGNIFICANTLY greater risk of twisting Loader arms while using a bucket and catching the corner on something.
A plow generally has a relief valve on the angle cylinder, and the blade or edge trips.
That said, for commercial or heavy duty use a frame mounted plow is certainly more durable and less prone to damage.
/ SSQA Snow/dirt plow blades #11
I've been running a loader mounted snow plow on my tractor for decades
I have power angle, but no tilt function.
/ SSQA Snow/dirt plow blades #12
Wouldn't "TILT" be rolling the SSQA plate back and forth with the loader curl function? That changes the angle-of-attack slightly of your blade.
/ SSQA Snow/dirt plow blades #14
The original poster mentioned he want a tilt function, I can only assume he meant side to side tilt.
That was my take also, but I wasn't sure what the term would be. My blade "tilts" left and right a few inches, but not operator controlled. It follows the contour.
/ SSQA Snow/dirt plow blades #15
I have a SSQA blade, it will pile deep snow up into some quite tall piles. It also works good for pushing snow off the edge of the driveway when the plow berm gets larger then I like and to have room for more. It does stick out in front of the tractor quite aways and it's not my first choice for snow plowing, I actually prefer my rear blade set at an angle and pulled behind me.
For some reason I can't attach any more pictures to this post.
/ SSQA Snow/dirt plow blades #17
It's still acting up but you can click on the jpg title and the picture will show up.
/ SSQA Snow/dirt plow blades #18
I ran my plow A frame under my loader arms, doesn't stick out far at all. (9' Western snow plow)
/ SSQA Snow/dirt plow blades #19
He also said he wanted a combination "snow/dirt blade" but later corrected that. I guess we'll have to let him explain the "tilt" requirement.
A blade on a loader that goes up/down/angle left/angle right and then also could somehow tilt side-to-side would be something very unusual. Would also require more than just loader controls with a 3rd function.
/ SSQA Snow/dirt plow blades #20
......also could somehow tilt side-to-side would be something very unusual.
Some dedicated snow plows have some slop built into the design. That way the plow can follow the contour and camber of the drive independent of the tractor.
