2005 NH TC29DA
/ 2005 NH TC29DA #1
ranger13256
Member
northville, ny
New Holland
My 2005 NH TC29DA has an intermittant starting problem. Some days I turn key, let glow plug light go out and it starts great. Other days same procedure, just click, click. I keep trying and eventually it always starts, so far! I have read previous posts regarding this issue a long time ago including a NH bulletin suggesting a new starter relay. I was wondering if anyone has new insight into this issue.
/ 2005 NH TC29DA #2
The TC series has a problem with internal corrosion on the battery cables where they were pressed into the terminals. It allows volts to flow but not amps under load, hence everything lights up but cannot start. You cannot see it by visual inspection. You can bypass the cables with a set of jumper cables to diagnose it. Or just replace the battery cables to see if it fixes your problem. I matched mine up at O'Rielly's when I replaced mine on the TC40DA. Cheaper than getting the NH cables.
/ 2005 NH TC29DA #3
They also benefit from the starter relay mod. Basicly takes away alot of the load from the key circuit and puts it on a external relay...or you could have have a stuck starter.
Next time it just clicks hold it in the start possition and tap the starter with a hammer. Do this a few times. If it starts every time its your starter.
/ 2005 NH TC29DA #4
This thread will give you some insight on the starter relay modification. Key switches can be a problem also. I have yet to have cable issue, but it is well documented and I have performed the starter rely mod and replaced my key switch with NAPA one that is much more robust than the OEM.
TC33D wont start
/ 2005 NH TC29DA
I am in the process of changing out the battery cables. Easy enough to remove the ground cable and find a replacement, the hot cable is more complicated in that it has 2 extra wires built into it on the starter solenoid end. I know I will have difficulty finding the factory cables but does anyone have any ideas regarding part # CNH 87302269, REV A, A16930?
I believe that I will have to fabricate the 2 extra wires going to the alternator as stand alone items.
/ 2005 NH TC29DA #6
Messicks list that cable for 196.00 3-7 day delivery.
/ 2005 NH TC29DA #7
That’s what I thought too..
But as I was at Walmart one day I happened to stumble upon the exact cable I needed with 2 extra wires.!!
If ur not in a big hurry, give it a shot.
/ 2005 NH TC29DA
I checked everywhere online and at 3 local NH dealers for the positive battery cable. No local dealers had it in stock, all could order it for $ 206.00. I went to Tractor Supply and bought both positive and ground cables for $46.00. I had to add the 3 additional wires and just barely had enough room on the starter solenoid stud to make it work. My old fingers combined with working around the loader made it difficult. So far, no clicking and instant start! Hard to believe that battery cables can go bad!
/ 2005 NH TC29DA #9
Nice that you were able to make your own!
/ 2005 NH TC29DA #10
Cool
However, battery cables have been going bad basically since the year after they were invented due to corrosion.
/ 2005 NH TC29DA
Thanks for the replies, the tractor now starts with more gusto and no click. It obviously was not getting a full 12 volts to the starter.
Has enyone ever used a starter solenoid stud extender. I ordered one because I am not happy with the wires crowded on now. it is 5/16 x 24 thread, I believe.
/ 2005 NH TC29DA #12
As long as there tight and make good contact with the flat part of the eyelet the nut is really there just to hold it, not so much of a contact point.
/ 2005 NH TC29DA
So far, I have ordered 2 solenoid stud extenders, 1- 5/16 x 24 and 1- 5/16 x 18 and neither one seems to fit. Is this a metric stud? and if so, where would I find a stud extender? Any help will be appreciated
New/Unused SD Lanch SDLD25 Mini Crawler Dump (A61166)
New/Unused SD...
2021 Jayco Jay Flight 32BHS Camper (A62613)
2021 Jayco Jay...
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
JOHN DEERE 5403 TRACTOR (A62130)
JOHN DEERE 5403...
2019 Chevrolet Express Box Van, VIN # 1HA3GTCG9KN007839 (A61165)
2019 Chevrolet...
UNUSED JCT QUICK ATTACH 60" PALLET FORKS (A62131)
UNUSED JCT QUICK...
