LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,804
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
A new one is $3150
The only problem would be the metric pins it came with and whether they would fit the new bored slugsWell making progress on my flail mowers beam;
Working on the side gussets......................................done
View attachment 3730340View attachment 3730345
Getting it painted up, next step install
View attachment 3730346View attachment 3730347
Of course the other day one of my brothers came by, after I had butt welded the tubing and welded on the top and bottom straps. He was standing there and said would have been easier just to cut both ends off and just replace all the tube would have been less work and welding.
Yep, it sure would have, where were you last week with the good ideas![]()
I cut the old bored slug (pivot) off the damaged section and welded it to the new tubing.The only problem would be the metric pins it came with and whether they would fit the new bored slugsThe other issue would be the required bronze bushings with the same issue of fit
I got the BCRM-155 last year. That's what I paid for mine new and shipped to my driveway. It may have been a couple of hundred less, I don't recall exactly. All the pretty yellow labels turned white and mostly flaked off. They're cheap paper labels but the cutter works great.I don't know if this is allowed or not, mods do your thing.
I saw this on facebook marketplace a few minutes ago. Is is a good deal? Then my financial manager said no. It's anyone's game.
I do think it's a good match for my MF 451 though.
Greetings Leon, you’ve hit on a lot of points:
48 acres but divided into fields of 5-10 acres. Will be mowing some areas that haven’t been mowed for 5 years, mostly Canadian Goldenrod, assorted herbaceous weeds, and fescue with some saplings (mostly <2” diameter). Plan to mow these areas every other year after first cut. Hope to transform to prairie plants as resources allow, will then be burned every other year with a mowed perimeter. Plan to mow after pruning small orchard. Biggest use will be to chop cover crops, some tall and dense (rye, millet, sorghum, etc.). Currently use a 6’ rotary which leaves a windrow, making tillage difficult.
Some rocks, but not bad, soil is central Ohio glacial till. Most rocks are baseball or smaller.
Rugrats are at a safe distance.
Not sure about 2” cutting height, never tried.
I can drive slow and recut. Slow tractor work is my meditation.
Dormant season is fine for the non cropped areas. After woodies are chopped, prefer to mow early summer to give the redwings nest time.
Finish…not particularly picky. Mulched in place.
Thought I wanted hammers for the prunings and saplings, now not sure.
Spirals are fine.
Thank you for the help.
I see often mentioning of V-belt tension gauge which makes me wonder why are the manufacturers not using spring loaded tensioner, like shown in my old Ford 917L Special below - perhaps it's just cheaper to make them without one?
I bought this mower five years ago as a fixer upper and it has worked out very good without any need to mess with the belts, once I figured the correct belt length.
This is obviously light duty mower with side slicer flails and it does a nice job in mowing a field, as well as forested area, without any scalping.
This thread has been very helpful for me!
View attachment 4184713 View attachment 4184711 View attachment 4184719
Interesting both of the 917 flail mowers (74”) I have owned were NOT spring tensioned belts.I see often mentioning of V-belt tension gauge which makes me wonder why are the manufacturers not using spring loaded tensioner, like shown in my old Ford 917L Special below - perhaps it's just cheaper to make them without one?
My old 917 has a threaded rod & not a spring loaded tensioner as well. I'd assume patent issues or just being cheap.Interesting both of the 917 flail mowers I have owned were NOT spring tensioned belts.
I want to convert the current one and I was wondering if a serpentine belt tensioner would work to tension the belt.
I’m going to have to look at doing that.I had a 917 with the threaded rod as the belt tensioner. i drilled a new hole for the "L" bracket further in and put a rather stiff spring between the bracket and the adjusting nut with a locknut behind it.
