Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience
   / Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #41
Not sure I like the fact they are a 4 stroke with no oil sump.
Like you, I'm having some serious issues (possibly just mental, though) about A) A 4 stroker with mix and B) the lack of an oil sump. I get it though, diesel is just a dirty mix of oil & a form of gas (yes, I know that's a stretch) without sumps and 2 strokers don't have sumps.
I guess my biggest issue with these is, if you have to have pre-mix, why not stick with a 2 stroker? More torque, in some cases more fuel efficient, etc.
Maybe I'm just getting old and set in my ways. Nah, I'm still just a young whipper-snapper at 66. 😂😁🤣
   / Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #43
In response to the better connection system that Stihl uses, compared to the Echo. Below is Echo's that using a pin. The camp will not compress the connector onto the tools shaft. It stays slightly lose and its lock pin is harder to get tools on/off. Have broke them. View attachment 3619259View attachment 3619260
Below is Stihl's Kombi system. They use key and keyway system to keep it from spinning, then the camp does compress onto the tools shaft. These are much easier to get on/off and the drive shafts ends are designed differently and goes together better.
View attachment 3619263View attachment 3619264
Something is wrong if the clamp isn't tightening down on the tools shaft, if you weren't able to get it tight and the pin was the only thing holding it I can see where you would be having problems.
The pin is only there for rough alignment, not to hold the attachment.
Did you address the issue with your dealer?
   / Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #44
Are you sure? I own 4 and we started using them 20 years ago, and they did the same back then. (Different machines) Echo designed the pin to hold it on. The casting has a spacer on it to keep you from crushing the tool shaft when you tighten them down. Check with your echo dealership. I do like stihl clamps better.
   / Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #45
I own a PAS266 and have used other Echo pas units, all tighten down on the tool and have no play. On mine, once tight,the pin could be left locked open and it wouldn't make a difference.
   / Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #46
I have a mixture of Stihl, Echo and Husqvarna power tools for trimmers, brush cutters, etc. For the Kombi systems I have both Echo 2620 and 266. Both have been flawless and enjoy the attachments. I also have an Ergo battery trimmer for just quick trimming around the pool and house. I love it for just quick jobs. Light and so quick to use but yeah, like you said it would get really costly to have enough batteries for serious run times. I only got it because I got the leaf blower too as a combo deal. Leaf blower handy to dry off car/truck/motorcycles after washing and blow out garage.
My cans are well marked in LARGE letters but apparently I cannot read my own labels or writing 🤨. Blaming SWMBO, she will not pick up any gas powered equipment, to heavy, even some of the battery tools the weight is complained about. So she bought her own lightest weight tools she could find, so she has hers and I have mine and any screw up... it's all on me. 😬
It took me longer than 10 years but I finally learned ALL mistakes are my mistakes... because I should have known my help was needed.
Sometimes we can be slow learners.
I stumbled on old song that I sometimes play for the wife as a better option than arguing with her when she is clearly wrong. She usually leaves my presence so I do not get to see her laughing.
I google it on the speaker when she thinks she is winning a debate
I think is is from 1962 and by Count Basie and is called
Alright, Okay, You Win
   / Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #48
I have a KM130 bought new in 2014. I've had zero problems with it and can highly recommend a Kombi tool. It starts every time on the first or second pull and runs like a champ. I've got the weed whacker with two solid blades and string trimmer, the chain saw, leaf blower, rubber brush sweep, hedge trimmer and an extension shaft. I use only the Stihl two stroke oil with 90 octane ethanol free gas. Can't say enough good things about this piece of equipment.
   / Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #49
I have a Stihl KM-131 that I've had for 3+ years now. It has been completely trouble-free. I have many attachments for it. Some get used frequently (string trimmer, brush blade), some less often (cultivator, rubber brush). I like that it is very powerful and just simple and reliable. I've also had a Stihl BR-600 backpack blower for maybe 8 years. Bought it used. It has likewise been trouble-free and just works. When I buy stuff I like to buy something more capable than I need in the hopes that I never outgrow it.
   / Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #50
The Stihl 4Mix engines are awesome. I've had my KM130 (Kombi unit) for 10 years now, it has been flawless and is by far the easiest starting tool I have and its unmatched in power. The downside is they are heavy, I used to use this as my main trimmer when I was doing lawncare but eventually picked up a lightweight trimmer just for the weekly trimming. But for the heavy work like brush cutting, tree trimming, edging and everything else I used it for its unstoppable. My Stihl blower is 4Mix also and I really prefer to listen to that for hours on end every fall over my 2 stroke blowers. Run good synthetic oil (I used to run the Stihl HP Ultra, now Amsoil Saber) and they will run like a top.
   / Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #51
My take on a 4 stroke and still have to mix gas and oil, What's the point?
Its better to have a dry sump than a tiny crankcase with a small amount of oil, especially when running the unit on its side or upside down for extended periods of time. Its actually a great idea and works great.
Update.
I did purchase the Stihl KM 131 (4Mix) Kombi powerhead. Just working through the first tank of fuel with the line trimmer attachment. It seems to have more power than will be need for trimming and even heavy weeds but did I get the Bed Re-definer attachment that will likely use more power since it is digging into the dirt.
Only thing I. do not like so far is the cold start process which calls for full choke then when it starts to release the choke by opening the throttle by operating the trigger throttle.
Most times it stalls out and requires a restart. After running a few tanks of fuel through the engine if it is still doing this, I will likely raise the idle RPM some in and effort to avoid the initial engine stall when pulling throttle to release choke. If that does not fix it I will have dealer look at it.
I appreciate easy consistent starting with no more than two pulls on the recoil starter.
Summary. Thanks to all of you for your great input and help empowering me to lighten my wallet.
Now with the Kombi Attachments I can keep buying more tools and spending more.
Currently I have the Line trimmer and Bed re-definer attachment. Will get the blade edger this week for son, daughter and their older retiree neighbors that have concrete drives and sidewalks (thankfully I do not have any edging at my country home).
My wife's birthday is coming up so she might want a rotary brush attachment and a pole saw attachment to add to her tractor with implements.
Thanks again for your input to my post.
Best regards
   / Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #53
Absolutely the best. My Kombi is 25 years old and I have never used any special gas or Stihl mix oil. It runs great today and beats my electric Stihl every time!
   / Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #54
Update.
Best regards
We find running large strings is what takes the greatest hp.
   / Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #55
Update.
Best regards
I'm sure you will like that trimmer. Do yourself a favor and get an Echo SpeedFeed head for it. I run them on my Stihl trimmers, and they feed well and reload much faster.
TractorTech
Good to hear on your old equipment. I love keeping good equipment running forever.
I typically use VP red 2 cycle synthetic oil at 45:1 (like to be conservative). I think it is a lower cost of Echo Red Armor. Usually get it at Walmart or other stors for $12.99 for 16 ounce dispenser bottle. Sometimes at season end I find it marked down lower.
What electric Stihl equipment have you used. I like the battery Stihl except for the high price of the batteries and the less run time.
ArlyA
That is a good point about the larger diameter line using more power.
For light residential use I usually use 0.080 inch but do change to either 0.095 or 0.105 when in heavy weeds.
Another good reason to get the largest displacement unit of the 3 Stihl Kombi Power Heads (KM91R/KM111R/KM131R). Interesting the 3 units were all the same weight so the choice was easy. IIRC the KM131 develops about 1.9 bhp which is more than any trimmer I have used in the past as mst are about 1.4 bhp.
Thanks
RjCorazza
I will have to get Echo Speed Feed Head as I hear many including you suggesting the change.
Our Redmax and Husqvarna Line Trimmers still have what there brand heads on them but I need to try the Echo
Thanks
   / Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #59
I don't find any issue with the run time, I have both the two of the AK20 and five of the AK30 batteries I use them in a string trimmer and blower. I did not buy the AK20's they came with the tools, I much prefer the AK30 batteries. I can get anywhere from 30 minutes to an hour depending on use. They do tend to run down about the time I am ready/need for a short break, usually when I am as far away from the other charged batteries as I can get.
As for cost of the batteries, I find them in line with other battery tools which are all costly.
   / Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #60
TractorTech
It is an FSA86R. And yes, the batteries are expensive! What I don't like; when it runs down, you need to have another battery ($$$) or wait for it to charge. Also, the head that came with it, Autocut C 6-2, is absolutely the worst. I have some $99 B&D trimmers with better heads. The Stihl head jams and is a pain to remove. I can't understand how a company that has been making heavy duty trimmers for so long could come up with an absolutely atrocious design like this.
2020 BOBCAT E55 EXCAVATOR (A59823)
2020 BOBCAT E55...
2018 JOHN DEERE 323E SKID STEER (A60429)
2018 JOHN DEERE...
CATERPILLAR 72" HANG-ON WHEEL LOADER FORKS (A60429)
CATERPILLAR 72"...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
78in Bucket Skid Steer Attachment (A59228)
78in Bucket Skid...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A61306)
2023 Kubota...
