Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience
   / Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #31
No matter what you think of its 2-4 stroke power plant, they have lots of other features we like over the Echo and Honda's we used and owned over the years.
   / Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #32
I would like to put a Echo string trimmer head on it but so far haven’t done that either, the Stihl trimmer head is a big pain to put string in.
I never seemed to be able to restring the bump head without the stuff getting bound up inside so I changed to one of these heads. Using .155 line (same as the Cub big wheel trimmer uses) it lasts for a LOOONG time and really works great on the heavier vegetation that I use the gas trimmer for. While it is not a bump and go head it only take a moment to replace the line.
   / Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #33
155 string is great to use but tough any trees, bushes or a house you like.
   / Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #34
No matter what you think of its 2-4 stroke power plant, they have lots of other features we like over the Echo and Honda's we used and owned over the years. View attachment 3582206
Like what? Haven't really used the Kombi setup.
   / Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #35
I have a thread about the Stihl and its kombi setup which we like better than the Echo. I can't find it at this time so please allow me some time..
   / Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #36
It took me about an hour of searching the internet to finally figure out how that engine is suppose to work. And even the authors of the info I found were not completely sure of how it works. Plus it appears that Sthil has had trouble with their plastic cam gear.
That was one factor why I didn't get one, although the failure rate may be overblown. Mostly I just like two strokes.
The 4-mix oils the engine by circulating incoming fuel/oil/air mix through the bottom end, past the cam and followers and through the valve cover. It's not a lot of oil but it's enough for mostly ball and needle bearings.
   / Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #37
I have a HT103 pole saw I bought new in 2018 and it’s been fantastic. I use canned fuel as it’s not used weekly over the summer and I’ve adjusted the valves once. It always starts and runs well.
Some common complaints of the 4 mix are due to the weight.
For trimmer, I went with a Milwaukee M18 fuel and love it. I have the original one, then I got the quick lock version with some attachments including the articulating hedge clippers and just got the bicycle bar brush cutter.
   / Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #38
Part of the reason I switched over to DeWalt was that the batteries for trimming are the same ones I can use for my drill and other power tools.
Got the pole saw/hedge trimmer combo and the string trimmer that swaps with a blade for brush.
There are jobs that need the gas options, but I love being able to avoid the hassles of those small engines. The batteries last longer than I can. It's hot and humid in NE Texas all summer long. One beauty of retirement is being able to adapt my schedule to my life rather than my life to my schedule.
   / Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #39
Want to add a Commercial Line Trimmer and Blade Edger to my tool/toy list, so thinking about purchasing a Stihl Kombisystem where you can use one powerhead unit with a changeable line trimmer head and a blade edger head. With my yard, older retirees yards, and kids yards I maintain 5 yards one day a week during growing season. Thus I have about 90 minutes of line trimmer weekly runtime and some concrete blade edging once a month at the one location with the 4 yards that are together. Currently using 22 plus year old 2 cycle Redmax Commercial dedicated trimmer that works like new. Just adding trimmer/edger at the second location to avoid having to transport equipment. The new equipment will be used for the 4 yards that are together.
First started looking at the battery powered commercial power heads (KMA 135 R and KMA 200 R). They appear to have sufficient power but no longer considering due to high battery cost and runtime that would require (3) $300 batteries and charge time. I like operation of the battery systems, just not the cost and runtime. Someday if battery cost reduces and capacity increases.
So now looking at the Sthil 4 cycle commercial powerheads. While being 4 cycle they still require use of 50:1 gas oil mix for engine lube since these engines do not have a dedicated oil sump crankcase. Stihl used to call these 4 cycles "4 MIX" but no longer use that name now calling them 4 Cycle.
What I am wondering does anyone here use the recent commercial Sthil 4 cycle powerheads and what are your experiences good and bad. I typically only run the trimmer fast enough to cut the grass to avoid scattering grass clipping debris on landscaping and me. With a conventional 2 cycle like my Redmax unit. this results in spark plug oil loading and requires me to run the engine RPM up to clear plug every 10 minutes or so. Hoping the 4 cycle with gas oil mix does not load the pug up with extended low speed operation.
The Powerheads I am considering are Sthil KM94R, KM111R, or a KM131R (28, 31, 36 cc displacements).
Any thoughts good or bad for my intended use.
Best regards
I have the 131 Kombi head. Don’t use it commercially but I do use it a lot. I’ve had it for 15 years or so. I have hedge trimmer, pole saw, string trimmer and blower attachments. I use the string trimmer and blower the most. Never had any of them them back to the shop for service. Marine gas w Stabil and it always cranks. I would buy same again if needed.
   / Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #40
In response to the better connection system that Stihl uses, compared to the Echo. Below is Echo's that using a pin. The camp will not compress the connector onto the tools shaft. It stays slightly lose and its lock pin is harder to get tools on/off. Have broke them.
Below is Stihl's Kombi system. They use key and keyway system to keep it from spinning, then the camp does compress onto the tools shaft. These are much easier to get on/off and the drive shafts ends are designed differently and goes together better.
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
2013 GREAT DANE  TANDEM AXLE 48FT DRY VAN TRAILER W/CRANE (A59575)
2013 GREAT DANE...
Utility Cart (A59228)
PJ  32 FLATBED GOOSENECK (A58214)
PJ 32 FLATBED...
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
