Uncle's JD 4230
/ Uncle's JD 4230 #1
bindian
Super Member
Willis, Texas
Mahindra 6520 4WD
I attended a cousin's funeral last week, in the Texas Panhandle. After the service, we drove out to Grandpa, then my Uncle's, now my cousin's farm. It broke my heart what I saw. The farm house my Dad was raised in needs to be tore down. The brick house my Uncle built in the 1980s needs to be gutted and redone, because of vandals. But what really broke my heart was seeing the 1973 JD 4230, bought new, sitting in it's shed, the roof blown off around it and hadn't moved in 12-13 years. I waited a day after getting back home to talk to my cousin. We agreed I could have it for $5,000. Grandpa had a D Model I wanted, but Uncle Woody (yes, that was his name) traded it in on the 4230. Sentimental value, to me, is priceless. Only problem it is 580 miles from me. Question I have, should I put a new battery in, check fluids for ugly colors and smells, hit it with some either, after cleaning or replacing the air filter...............and try to crank it up to drive it onto my trailer? Or, since it hasn't ran in 12 or more years, just get it to roll and winch it onto my trailer?
/ Uncle's JD 4230 #2
Looks like a good find. Keep us up to date how the starting or loading process goes. Will you try soon?
/ Uncle's JD 4230 #3
She should light right off after you check the vitals and give her a new battery. I get sucked into watching Diesel Creek on YouTube firing up equipment that could be that Deere's grandpa !
/ Uncle's JD 4230 #4
Double check for water in the fuel before trying to start. Injectors and water don’t mix to well.
Maybe give the wiring a good looking over for mice or rodent damage. Them little varmits seem to like some types of wiring and that can would keep them out of the weather and away from predators.
Wish you the best on getting it home.
/ Uncle's JD 4230
My Caterpillar E70 was rebadged from a Mitsubishi MS70. A 2000 year model. The wiring was a soy based insulation. Mice and rats love it. It started smoking and I got the battery disconnected in time, but lots of burnt wiring. I replaced all the wiring and all the starting circuit hardware. Old school machine with wobble sticks, not joysticks. So old it has glass fuses in the panel.
/ Uncle's JD 4230
I will sump the tanks for sure. Was an aircraft mechanic for 42 years. Retired early with help of covid bonuses. We sumped a/c tanks daily. Thanks for the reminder!
/ Uncle's JD 4230
I've never used ether down here in the Piney Woods of Texas. How much ether is too much?
/ Uncle's JD 4230
I have to get a surgery I have been putting off before going to get it. Hopefully August.
/ Uncle's JD 4230 #9
Unless modified it uses 2 - 6volt battery in series. I would avoid either at all cost and if electric available plug in the block heater and get here good and hot. Put a battery charger on her in case it takes several attempts to get it to start. Only boost from the starter on 12 volts. I would also replace the fuel filter and check the air filter
/ Uncle's JD 4230 #10
IMHO any amount of starting fluid that doesn't pass through the starting fluid port on the dash is TOO MUCH. Starting fluid adapter has a built in orifice that limits amount of starting fluid that can enter engine at one time.
I always attempt to start engine without utilizing starting fluid. Piston rings & piston lands have been damaged by using too much starting fluid.
I suggest to change fuel filter then check for good fuel flow from tank tom inj pump. If installing batteries I suggest to change to either one group 31 or two 12 volt batteries attached in parallel if tractor still has two 6 volt batteries attached in series to yield 12 volts.
/ Uncle's JD 4230 #11
Good advice, keep the either bunny away if possible, more of a last resort and then sparingly.
/ Uncle's JD 4230
I have always heard about ether can wash out the cylinders. I will try to start without ether. I hope to be there in August (still hot) and not need to plug in block heater.
I will have to wait to see what battery or batteries are installed, then drive 40 miles to get what is needed and any other cables.
Do you think the diesel will be good enough to start and load on the trailer? It's been sitting around 12 years as is.
I think it is time to buy manuals for it.
/ Uncle's JD 4230
Just talked to my cousin. He says he will look for the manuals when he goes (50 miles) up there to mow. He says he thinks there is one 12 volt battery. Is it located under the step on the left side? He says he remembers shooting ether into the air filter. He doesn't remember a port on the dash. Guess that is why they added a step forward of the JD steps in the photo.
/ Uncle's JD 4230 #14
First thing I'd do consering the time it's sat and in the weather is:
1. Bar it over to make sure it's not hydro locked.
2. Check the rad for coolant
3. Look underneath for any oil leaks and check the oil in the motor and loosen the drain plug to see if there is any water in the sump. Water will collect in the bottom of the sump and oil will be on top of it.
4. Check the air filter-cleaner for vermin homes
5. Replace the starting batteries and then roll it over to see if it's delivering fuel and attempt to start it not using starting fluid.
You might get lucky. With me, starting fluid is always the last resort.
/ Uncle's JD 4230
Oh yeah, bar it over. Thanks for mentioning that. Planning all fluid checks for being normal, then changing oil and filter, changing fuel filter, checking for fuel flow. After getting tires to hold air.
/ Uncle's JD 4230 #16
IIRC using a bar to turn flywheel on this model JD is very difficult. Hole to access flywheel teeth is on the RH side of engine.
/ Uncle's JD 4230 #18
Can you use the bolt holding the harmonic balancer on front of engine to roll it over. Not sure how buried it is either.
Other option might be remove the starter if it gives you better access to ring gear.
/ Uncle's JD 4230 #19
I would recommend carefully loosening the oil and hydraulic drain plugs just to the point of leaking a little bit and looking for water before any thing is disturbed or rotated.
As far as using ether on an engine very limited amounts while it is cranking over will work. Just don't spray a bunch into the air filter or intake and then go and start cranking the engine over.
/ Uncle's JD 4230
Just watched this You tube video of two farmers changing the hyd. pump. With the radiator out, it is wide open to get a pipe wrench on the pump coupling to turn the engine over. Opening from below is doable, but not much room to turn the pipe wrench handle.
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
Case Axial-Flow Combine Wheels NO RESERVE (A63118)
Case Axial-Flow...
2019 Lynco Mini Mover Aircraft Tug Cart (A64553)
2019 Lynco Mini...
1979 Donahue Dump Trailer (A66285)
1979 Donahue Dump...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
2015 Bandit 200UC Chipper (A63689)
2015 Bandit 200UC...
