Rear remote studs- Where to find?
/ Rear remote studs- Where to find? #1
OldTrix
none
I'm adding a second rear remote to my Mahindra 2665, and I will need longer studs to accommodate the two valves. It's an M10-1.25 stud, and I'm looking for a 195-200mm stud to fit. So far, McMaster, Graingers, Fastener mart have all been fails. Does anyone know a source for long metric studs?
/ Rear remote studs- Where to find? #2
If all else fails, you can always use all threaded rod.
yeah, saw that, was hoping to avoid threaded rod. Looking at 195mm bolts now, don't really need a double-ended stud to hold down the stack.
I found a couple places that sell a M10-1.25 x 195mm bolt, one on ebay the other online place called hammerhead racing. Wait and see what I get. McMaster and Grainger, were surprisingly useless, as were most online metric bolt shops, along with my loca. hardware store, auto parts store, and even the old Mahindra tractor dealership.
I'll have to hit up the Kubota dealer next time I'm over in NH. My local tractor dealer truly sucks. Couldn't be bothered to even look...
/ Rear remote studs- Where to find? #7
/ Rear remote studs- Where to find? #8
You could get a longer bolt, cut the head off and pick a die of your liking (within reason) to create the missing thread.
/ Rear remote studs- Where to find? #9
What about a 200mm bolt and cut some off? Theres plenty of ways to do this and not need the specific bolt length.
The bolts I purchased at Hammerhead were some sort of snowmobile track bolt. Should work. I was hoping to find a hardened stud, similar to what I removed. Given the commonality of these tractors and rear remotes, I was surprised at the scarcity of viable parts. TYM/Mahindra/Kioti/JD, et al have to be buying them from someone...
/ Rear remote studs- Where to find? #11
Maybe here...... Bell Metric... If you want metric bolts, nuts, washers, etc: go to a metric supplier.....
More specific....
wrong thread- I need M10-1.25, not 1.5
/ Rear remote studs- Where to find? #13
Well instead of "stud" try threaded rod....
/ Rear remote studs- Where to find? #14
Not a stud, but this may be a source for the future if you're not happy with what you've found.
yeah, I found plenty of Ti bolts, for around $30/ea... nope.
I have a set of chinesium bolts as well as the set from hammerhead enroute. Will just have to remove the toolbox to set everything in place with the greater height/length of bolts.
/ Rear remote studs- Where to find? #16
I found a number of Chinese sources, but I'm loath to send anyone to them. I have worked for a Chinese company and they'll try to get away with anything they can. This is freely admitted to by the Chinese nationals I've worked with. I wouldn't trust a grade 8 bolt of theirs to be anywhere close to grade.
agreed, I also avoid them for the same reasons. Most of it is crap.
2025 Swict 60in Bucket Skid Steer Attachment (A61567)
2025 Swict 60in...
1975 TRANSPORT SYSTEMS 35LX AD DOUBLE DROP (A60736)
1975 TRANSPORT...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A59823)
2018 FREIGHTLINER...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
MODEL 14C SCRAPER (A58214)
MODEL 14C SCRAPER...
2019 PJ  40FT GOOSENECK TRAILER (A58214)
2019 PJ 40FT...
