Rear remote studs- Where to find?
   / Rear remote studs- Where to find? #11
Maybe here...... Bell Metric... If you want metric bolts, nuts, washers, etc: go to a metric supplier.....
More specific....
wrong thread- I need M10-1.25, not 1.5
   / Rear remote studs- Where to find? #13
Well instead of "stud" try threaded rod....
   / Rear remote studs- Where to find? #14
I'm adding a second rear remote to my Mahindra 2665, and I will need longer studs to accommodate the two valves. It's an M10-1.25 stud, and I'm looking for a 195-200mm stud to fit. So far, McMaster, Graingers, Fastener mart have all been fails. Does anyone know a source for long metric studs?
Not a stud, but this may be a source for the future if you're not happy with what you've found.
yeah, I found plenty of Ti bolts, for around $30/ea... nope.
I have a set of chinesium bolts as well as the set from hammerhead enroute. Will just have to remove the toolbox to set everything in place with the greater height/length of bolts.
   / Rear remote studs- Where to find? #16
I found a number of Chinese sources, but I'm loath to send anyone to them. I have worked for a Chinese company and they'll try to get away with anything they can. This is freely admitted to by the Chinese nationals I've worked with. I wouldn't trust a grade 8 bolt of theirs to be anywhere close to grade.
agreed, I also avoid them for the same reasons. Most of it is crap.
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
UNUSED LANDHONOR LHR-RF24 RATCHETS & TOOLBOX (A54757)
UNUSED LANDHONOR...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A55302)
2023 New Holland...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2007 DRAGON 150...
2019 BOBCAT T630 COMPACT SKID STEER TRACK LOADER (A55218)
2019 BOBCAT T630...
