Rear remote studs- Where to find?
   / Rear remote studs- Where to find? #11
Maybe here...... Bell Metric... If you want metric bolts, nuts, washers, etc: go to a metric supplier.....
More specific....
wrong thread- I need M10-1.25, not 1.5
   / Rear remote studs- Where to find? #13
Well instead of "stud" try threaded rod....
   / Rear remote studs- Where to find? #14
I'm adding a second rear remote to my Mahindra 2665, and I will need longer studs to accommodate the two valves. It's an M10-1.25 stud, and I'm looking for a 195-200mm stud to fit. So far, McMaster, Graingers, Fastener mart have all been fails. Does anyone know a source for long metric studs?
Not a stud, but this may be a source for the future if you're not happy with what you've found.
yeah, I found plenty of Ti bolts, for around $30/ea... nope.
I have a set of chinesium bolts as well as the set from hammerhead enroute. Will just have to remove the toolbox to set everything in place with the greater height/length of bolts.
   / Rear remote studs- Where to find? #16
I found a number of Chinese sources, but I'm loath to send anyone to them. I have worked for a Chinese company and they'll try to get away with anything they can. This is freely admitted to by the Chinese nationals I've worked with. I wouldn't trust a grade 8 bolt of theirs to be anywhere close to grade.
agreed, I also avoid them for the same reasons. Most of it is crap.
2014 Ford F-350 4x4 Cab and Chassis Truck (A53422)
2014 Ford F-350...
UNUSED LANDHONOR 5/16" 7' G80 DBL CHAIN SLINGS (A54757)
UNUSED LANDHONOR...
2010 Hyundai Elantra Touring Sedan (A55853)
2010 Hyundai...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A54814)
2012 Crane Carrier...
1991 INGERSOLL RAND SD-100D VIBRATORY ROLLER (A52705)
1991 INGERSOLL...
2017 Kubota K008-3 Mini Excavator (A54865)
2017 Kubota K008-3...
