The Life of a Custom Mowing contractor
   / The Life of a Custom Mowing contractor #1,381
I could “push it” on them to hay it, but if I upset a few people, could lose all of it.
Sometimes you have to know when to leave well enough alone.
When dealing with a HOA the less said the better.
Out of the blue, on Friday I got an interesting call. A current customer of mine that has me haying their property in our little town, has offered me 92 acres about 20 miles from me.
It was row cropped up until 2023, but has been fallow since then. Owner unhappy with amount of chemical application and messy habits of previous farmer.
They want the weeds that have taken over the fields mowed for this spring and summer to get it under control. So at least 2 cuttings. That’ll be good money.
They asked me for suggestions moving forward on how to keep it looking good without intense row crop farming, until they decide what they want to do with the property.
I suggested a mid August burn down, then drill seed with a 50/50 mix of orchard grass/fescue along with a 2nd application of winter wheat for ground cover through the fall/early winter.
Next year it would be baled for grass hay.
The customer is a wealthy developer and knows little about farming, mowing, etc. I expect they’ll be kind of shocked at the cost, so I am only slightly optimistic it’ll happen.
If it does, it’ll yield a lot of hay.
   / The Life of a Custom Mowing contractor #1,385
So? Does he pay you for mowing? Or do you pay him for the hay?
   / The Life of a Custom Mowing contractor #1,386
How many hours in the seat does it take to mow 92 acres? My back is hurting just thinking about it.
I can mow about 5-6 acres per hour, so I figure (2) 8+ hour days.
The comfort of the tractors is pretty good. No back issues, but the legs get kind of stiff after sitting a long time. I usually go for a long healthy brisk walk with my wife in the evenings to work it all out.
Been prayin a lot lately. I am maxed out on the work load I have now, but I know I have to keep expanding.
All the Glory to God.
   / The Life of a Custom Mowing contractor #1,392
The more glory I give the Lord and the more I pray and put him first, the better my life gets.
My 7 year old granddaughter was baptized this morning and I said to myself what more can a man ask for.
   / The Life of a Custom Mowing contractor #1,393
I'm always thankful for how the amount of time I have and the work coming in seem to match fairly well.
   / The Life of a Custom Mowing contractor #1,394
Fellas, let's all read that line again.
Seems this could apply to more than stiff legs. Could apply to solving many of life's problems
Few Action shots from today. All the while I’m like “dang, I need to start mowing hay”….
This is a 9 hour mowing job. Got underway at 7AM on a nice sunny day.
Easy mowing, light field grass & weeds.
Storm Drainage reservoir
Typical uneven gulley at the bottom of a steep hill.
I really need a large tool box mounted to the mower for blower, spare blades, greaser, etc. would be great to have DC wire run 🏃 side of it to keep dewalt battery charged for greaser & impact.
The "biggest small" improvement that could be made to our tractors is a large storage compartment with an AC/DC inverter so you can go out into the field with some tools, small chain saw, rechargeable tools, etc. for quick repairs.
   / The Life of a Custom Mowing contractor #1,398
This is one place technology is getting much better. Inverters are better and more affordable than ever.
I was thinking it could pick up a wire lead out of the 7 pin plug on back of tractor and power a battery charger.
Inverters are great. Have one in the Ram and it’s surprisingly powerful.
   / The Life of a Custom Mowing contractor #1,400
If you make a pigtail to a 7 pin plug and use the hot lead (and also a ground) then your could use your inverter on any tractor, truck, or SUV that has a 7 pin harness. It would be totally portable.
2015 DODGE RAM 3500 4X4 CREW CAB PICKUP TRUCK (A59904)
2015 DODGE RAM...
5ft Rotary Brush Cutter Tractor Attachment (A59228)
5ft Rotary Brush...
2008 Tronair Disabled Aircraft Dolly (A59228)
2008 Tronair...
Toro z turn (A56859)
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
