bdhsfz6
Elite Member
- Joined
- Apr 11, 2015
- Messages
- 3,930
- Location
- Northeastern Pennsylvania
- Tractor
- Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
Yeah, I know, mower blades have been a frequent topic here but it's been awhile and I'm always interested in new opinions, products or ideas.
For many years, I resharpened my blades with varying degrees of success. Usually, I get two seasons out of a set of new blades before they need attention. After resharpening, I'm lucky to get a single season before the cut begins to look ragged. I use an angle grinder with a coarse wheel or flap disk, depending on how much material needs to be removed. I quench frequently to avoid overheating but the temper never seems to be as good as the original.
The biggest problem I have with resharpening is re blunting the blade ends after they round off. It usually means removing 1/4 to 1/2" to square it up. This can cause a balance issue and the vibration is quite noticeable on my 3 spindle, 3pt finish mower. For some reason, it wasn't a problem on my old 2 spindle mower. I try to balance the blades after sharpening but have limited success.
I've also found that high lift blades don't seem to last as long as low or medium lift. The high lift do a better job on wet or damp grass and are more resistant to bending when scalping. I usually mow the first time out with an old set of high lift to clear any obstacles before switching to low lift.
I've come to the conclusion that it's no longer worth my time to sharpen and balance 3 blades every year. I now just replace them every other season. Cost's just under $100 and well worth every penny.
Of course this is just my opinion, YMMV.
