Barndominium/Shop or "real" House?
/ Barndominium/Shop or "real" House?
Very nice work and well thought out - and you have all the tools and machines to make it look easy. Its a lot of work working alone, doing conduit and backfilling.
Like the older iron you have the Ford 1920 with plow, the older Ford with land plane? and is that a JD BH or Case?
The backhoe is Ford 575D 4X4. I've owned it for 20 years now, it's done a lot of work.
To save money on all the fill I needed to raise the build pad I went with hard fill. Lot of chunks of concerte, asphalt and red brick. Made the conuit job a lot more difficult. Backfilled over the conduit with a few inches of 5/8 crusher run before using any of the hard fill. Tamped in layers as I went. Don't have a trench compactor.
/ Barndominium/Shop or "real" House? #542
Yes - saw the fill remnants in the bucket of the 575 - that makes it a lot harder, but you got it done. Here in NH the first 2-3 feet are comprised of glacial till rocks and boulders - not fun doing any piping or digging. Here, once you break through that 2-3' mess of glacial till its a nice sandy mix.
Your project looks very well planned, and you will have the satisfaction of knowing how its built and where everything is - IF you need to redo anything in the future.
I bought a jumping jack compactor to to compact around all the columns and my conduit trenches.
Unfortunately there was quite a bit of water pumping up in some spots.
I knew I should have put in a drain tile when I backfilled the build pad last year. I decided to start on that today.
I'll probably use 6" corrugated pipe with filter sock near the building and then switch to non-perforrated to carry the water away.
It's probably going to take a couple weeks to dry out the pad so I can resume compaction.
/ Barndominium/Shop or "real" House? #544
Is all that water from the water table?
Yes, the water table starts very high here in spring, and it's been raining pretty much every day for the last 3 weeks. From now until August the water table will drop about 5 ft.
However, this water was sitting under the building pad because of the way I put in my driveway approach to the building. So definitely want drain tile on this side of the building pad so every spring I don't have so much water under the concrete pad.
Pad Draining
I did put this drainage pipe in when building the driveway, to get water from one side to the other, but water is still getting underneath the building pad.
/ Barndominium/Shop or "real" House? #546
Do you have enough slope to take it to daylight or are you going to have to use a drywell tile.
There is a drainage swale about 100ft from the building, I've already rough trenched out to it to get the water away from the pad.
I don't have any kind of fancy laser setup when I dig so will have to go back over everything with my transit when placing and backfilling the pipe to get proper pitch.
So I am mostly finished with the drainage.
That grate on the tee fitting is temporary, I will eventually connect that to the gutter on the lean-to.
My big decision now is whether or not to go with floor drains. The drains will ultimately be going to daylight so I don't need p-traps for sewer gasses. My plumber is recommending to go with drop-in check vavles to keep out drafts in the winter and critters year round.
I checked on the NYS DEC website and a permit is not required for a residential garage drain exiting to daylight. I also asked my building inspector and he says a permit is not required.
These 3 bays will be for parking, and the drains are for snow/ice melt in the winter.
When I do the concrete in the shop area, whatever floor drains I put in will likely need an oil separator, because that's where work on vehicles and equipment will happen. However, I don't see on the DEC website that this is required. It is if you are connecting to a city sewer system, but not to daylight.
I guess my question is, are floor drains really worth it? I already ordered the drains and the PVC stuff is not that expensive. I'm just wondering if I'm making the concrete contractors' job harder by asking him to slope to 3 drains. Is that more difficult than sloping to three OH doors?
I'm still on the fence whether or not I want them. Seems like whatever I decide, in the futue I will wish I had chosen the opposite.
/ Barndominium/Shop or "real" House? #549
You live in the snow belt if I recall. Parking a snow or slush covered vehicle in the garage WITH drains is a lot less messy and more efficient when dealing with meltoff.
Putting it in now will be the easiest chance you'll get.
/ Barndominium/Shop or "real" House? #550
The ditches sure dried out nicely. It's smart to take lots of pictures of what you are doing. It seems like it would be easy to remember where everything is, but in ten years, those pictures will be priceless!!!
/ Barndominium/Shop or "real" House? #551
It's nice to be able to wash salt off vehicles in winter, and if your cleaning motors or oily equipment a separator in one bay drain would be a good idea.
/ Barndominium/Shop or "real" House? #552
Agreed! I am almost a year and a half post build and I have used my pictures and videos more times than I can count.
I have a pretty big library of pictures from the day I bought this property 22 years ago until now. There are quite a few things I wish I had more pictures of, especially from the years I didn't have a smart phone.
/ Barndominium/Shop or "real" House? #554
I would definitely go with the floor drains, nothing like tearing the weather seal off the bottom of a door because it froze down to the concrete. I'd also go with a separator basin of some type with a removable cover not only for grease and oils but also for the sand and dirt that will accumulate and then lie in the bottom of the drain lines.
Either one for each inside or one larger one outside.
/ Barndominium/Shop or "real" House? #555
Center drains in each bay are definitely the way to go, as Lou says. But I hear that a lot of local authorities have made it damn near impossible. I know some put the drain and then concrete over it for inspection, opening it up and finishing the job after inspection.
I even contacted the soil & water conservation dept. in my county today to ask about floor drains. They said as far as they know, there are no regulations for residential, only commercial. The DEC website talks about waste water, but the min quantity is 1000 gallons per day to require a permit, and that is when the drains are connected to a city sewer system. I don't know how many years it would take for snow and ice melt off of vehicles to account for 1000 gallons. And that I don't believe is considered waste water, it's the same stuff running off the roads being collected by ditches when the snow melts...
So I feel I've done my due diligence in terms of whether or not I am allowed to have floor drains that exit to daylight.
Only thing I don't like is all the authorities I have contacted state "as far as I know"... Can't get anything in writing, but I do have emails & text messages. I see no permits for floor residential drains on the DEC website to even apply for.
I think this may be at the town inspector level if they want to make it an issue, my building inspector is not making an issue out of it.
/ Barndominium/Shop or "real" House? #557
Parking area of snowy cars, how is it heated, or not. Floor heat helps it dry out. That is what I have along with floor drains. Because each drain is for one car and one door, the floor just sloops to the drain under the car area. Back wall along the work benches is flat. Jon
Also to add, my drains flow out the building to a type of dry well. Septic stone in a pit where the drain pipe stops and critters can't get into. I do not rinse car off in garage, Adds too much moisture into building. I rinse outside in freezing weather with hot water, then put car in garage to dry. Jon
/ Barndominium/Shop or "real" House? #558
I have four garages, two of them being two-bay each where I park vehicles. The one with center drains has nice flat floors all the way around the perimiter, which is great for work benches or parking machinery. But the one that slopes toward the doors is terrible, as the slope from side wall to door is extreme near the doors, meaning every tool chest or workbench must be shimmed level.
Of course, you can guess which one is my primary workshop, where I'm forever doing that. 😠
It was a backbreaking day today. But got all the garage drain plumbing installed:
Even though I had the ripper on the 4610 tractor to break up the compacted stone & hard fill, there was still a lot of manual labor. Lot of pick axe and shovel work.
I'm going to be using Sioux Chief 832 4" adjustable drains.
I didn't have a ton of elevation to work with. I set the drains to be 1" below the finished floor, with another 1/2" adjustment downward if the concrete contractor want's them lower for some reason. From my research a 1" depression sloping to the drain in an ~8ft x 16ft area should be enough for ice melt off of vehicles.
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
2018 FREIGHTLINER CASCADIA GLIDER 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
1989 FRUEHAUF TRAILER OPERATION FUEL TRAILER (A60736)
1989 FRUEHAUF...
1901 HOMEMADE 16FT T/A TILT TRAILER (A59906)
1901 HOMEMADE 16FT...
2012 PETERBILT 386 6X4 T/A SLEEPER TRUCK TRACTOR (A59906)
2012 PETERBILT 386...
84'' Skid steer bucket (A61567)
84'' Skid steer...
