California
Super Star Member
- Joined
- Jan 22, 2004
- Messages
- 16,869
- Location
- An hour north of San Francisco
- Tractor
- Yanmar YM240 Yanmar YM186D
Bad fuel recently gave me a nightmare of bad performance. This Yanmar YM186D is from early 1980's so after 45 years anything seems possible. But today I put in fresh diesel and to my relief, this solved the problem. It purrs again.
Last weekend I mowed, and spent some time grading the lane. Performance deteriorated from just rough idle, to frequent ran-out-of-fuel rpm drops or individual cylinders misfiring. I feared the worst. Something fouled the injectors? Governor is sticking? That's what it felt like. Full throttle under load did not make exhaust smoke as the rpms dropped.
Today I suctioned the fuel tank empty. Blew out the fuel line from the pump back to the fuel filter location with the the filter removed. Then went to the expensive Chevron station for fresh name-brand fuel. Used some of this to flush from the tank to the fuel filter location.
Put in a new fuel filter and refueled with the fresh diesel. Then bled the system as Yanmar recommends - filter inlet, filter outlet, then at the injection pump. The engine started instantly. Now it idles smoothly down to 600 rpm like it should, in contrast to recently where below 1300 rpm risked killing the engine. I did some more mowing under heavy load and it just purrs.
Lesson learned: I've always bought the cheapest gasoline and diesel. Never had a problem before. But the local Rotten Robbie brand red diesel I'm using up from a purchase last year, doesn't make the Yanmar happy.
I use Power Service gray bottle fuel additive. Anybody have a suggestion how to make my 15 gallons of crummy diesel on hand, usable?
