Major problem? No, just bad fuel
/ Major problem? No, just bad fuel #1
California
Super Star Member
An hour north of San Francisco
Yanmar YM240 Yanmar YM186D
Bad fuel recently gave me a nightmare of bad performance. This Yanmar YM186D is from early 1980's so after 45 years anything seems possible. But today I put in fresh diesel and to my relief, this solved the problem. It purrs again.
Last weekend I mowed, and spent some time grading the lane. Performance deteriorated from just rough idle, to frequent ran-out-of-fuel rpm drops or individual cylinders misfiring. I feared the worst. Something fouled the injectors? Governor is sticking? That's what it felt like. Full throttle under load did not make exhaust smoke as the rpms dropped.
Today I suctioned the fuel tank empty. Blew out the fuel line from the pump back to the fuel filter location with the the filter removed. Then went to the expensive Chevron station for fresh name-brand fuel. Used some of this to flush from the tank to the fuel filter location.
Put in a new fuel filter and refueled with the fresh diesel. Then bled the system as Yanmar recommends - filter inlet, filter outlet, then at the injection pump. The engine started instantly. Now it idles smoothly down to 600 rpm like it should, in contrast to recently where below 1300 rpm risked killing the engine. I did some more mowing under heavy load and it just purrs.
Lesson learned: I've always bought the cheapest gasoline and diesel. Never had a problem before. But the local Rotten Robbie brand red diesel I'm using up from a purchase last year, doesn't make the Yanmar happy.
I use Power Service gray bottle fuel additive. Anybody have a suggestion how to make my 15 gallons of crummy diesel on hand, usable?
/ Major problem? No, just bad fuel #2
Yeah, gunky fuel did a number on a car of mine many moons ago. Chevron or Shell for me ever since.
I've got a fuel tank to clean of some sludge that I think came from a lubricity additive that I used in the fuel for some older engines that had biodiesel in it that I think turned to a gum. What a mess.
All the best,
Peter
/ Major problem? No, just bad fuel #3
If the fuel is bad I don’t think any additive is going to make it good again.
/ Major problem? No, just bad fuel #7
He's in Kalifornia so using old diesel as an accelerant would get him a vacation in the barred hotel.
He doesn't have to report it to authorities
/ Major problem? No, just bad fuel #9
I have Off Rd. Diesel and Reg. pump. close to the house. No Taxes. High Fuel, prices would be the only reason for me to use it. The reason I don't use off Rd. is you I can't see the fuel filter or in the fuel bowl hardly for that matter. Had it out yesterday and looked in it! Super clean and it's been Hundreds of Tach hrs. since I changed it! Napa auto for the filter replacement.
/ Major problem? No, just bad fuel #10
Ah ha, you experienced what I found out back in 2014. I too learned NOT to visit the nearest off the beaten path mom+pop station to get off road diesel. After a few fill ups and running the tractor, I noticed hesitation, misfires and what-not. I went to the station like a dummy the next time. I asked the question, how often does the tank get filled. They paused to think about it. Then said, 4 YEARS AGOOOOOOOO. :eek:
I too learned how to drain and clean the fuel system from Aaron at Hoye's video. He saved my day!
(y)
From that point on, I only go to stations on major truck routes with fresh clean diesel for road use. The turn-over in the station tanks is very often. Not a single problem since.
I do the Seafoam additive before and during winter, and the Gumout Multi-System Tune Up from Spring thru Summer. This gives the best results. I tried the PowerServe with so-so results and gave up on that brand.
/ Major problem? No, just bad fuel #11
Sadly, none that I know of, I think in part because there are so many ways to go bad. (Oxidation, evaporation, algae, water...)
I'm also on "the buy from a station with high turnover" page.
All the best,
Peter
/ Major problem? No, just bad fuel #12
Here in Iowa, I will not run diesel from caseys stores. My truck runs horrible on it. Switched to Cenex or kwik star diesel and problem solved. In a pinch, I will do BP. So, I will only run Cenex or kwik star diesel in my yanmar also and will throw in some ATF as well
/ Major problem? No, just bad fuel #13
I picked up 3X cases of ATF last year for $1 per qt. on clearance. Looking to use it too.
/ Major problem? No, just bad fuel #14
All the best,
Peter
Had a bad experience with bio diesel with the Deere 350… the pump shop said bio is good for his business…
Since then it’s pay the price at Chevron which was $5.50 gallon last purchase.
/ Major problem? No, just bad fuel #15
My boater friends polish their fuel or have filters to separate water… it works but wouldn’t pencil out…
/ Major problem? No, just bad fuel #16
Chevron or Murphy. Chevron is the closer Murphy is cheaper. I still won't run the Chev. Off Rd.. They claim it's Reg. fuel pump Diesel. Just Dye for Off Rd use. It doesn't get used in my area very much! Decades ago when it was Rural so it sits in the Tanks for ? And you can't actually see it!! JMO..
Wow. Chevron red diesel up here in the North Bay was $4.49 yesterday.
/ Major problem? No, just bad fuel #18
No red here so it’s always highway taxed.
I am able in the tax return to list the number of diesel and gas used off road for a small break…
/ Major problem? No, just bad fuel #19
The local diesel is now hydrogenated vegetable oil (HVO, by Nesté for many brands) which burns more completely, less soot, reasonable lubricity, and no oxidation, so it has better storage characteristics. A big step up from ULSD, and from B5/B20 blends in my opinion. It has slightly lower BTUs/gal, but more complete combustion than ULSD, so net/net, it is within 1% or so of ULSD on MPG basis. Every vehicle that I have put it in has noticeably lower odor/smell out the tailpipe.
I'm happy to have it. I can't get red dye diesel locally, without going to a storage tank on site. I don't use enough to have that pencil out. I have thought about a double wall smaller tank like Western Global's FuelCube Type S. Anyone have any experience with it?
Mainly I worry about turning over the fuel often enough to keep it fresh.
All the best,
Peter
Try filtering it through a Mr. Funnel.
I went looking on Amazon for a Mr Funnel. The reviews are mixed.
One of the two videos show water pouring right through the Mr Funnel. A one-star review noted it filtered when new then after 10 gallons same as that video.
Is that an expired patent where anybody can name junk as 'Mr Funnel'?
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
Knapheide Service Body w/ Ladder Rack (A62613)
Knapheide Service...
2020 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2020 Ford F-150...
23ft. Zodiac Hurricane Inflatable RIB with 2007 25ft Myco T/A Aluminum Boat Trailer (A61574)
23ft. Zodiac...
Used Landpride GR1525 Stump Grinder
Used Landpride...
John Deere 5420 Tractor with Quicke Loader (A64047)
John Deere 5420...
