My well water is terrible. Should I just use pool water?
/ My well water is terrible. Should I just use pool water? #21
Oil and fracking wells are multiples deeper than a drinking well. It shouldn’t be an issue.
Ya, well ive seen the news shows that show how fracking affected house water, water became flammable. Whether or not thats true…..who knows.
Do your neighbors have the same issues? Maybe you need a relocated or deeper well. Being texas…..i just think about fracking and oil well waste products. I lived in lubbock for 2 years.
All the homes on my road were built in the late 80s and had surface well pumps. I think that necessarily means they were shallower than 30ft or so. The previous owner, along with several other people on my road, had new wells dug 15+ years ago I assume because of similar issues. I have a submersible pump and I have no idea how deep it actually is but the neighbor regaled me with tales of when the giant truck ruined his lawn in the process of drilling that well and he made it sound extremely deep. Like deeper than what is reasonable for any well to ever be, for any reason.
/ My well water is terrible. Should I just use pool water? #23
Post 12 is your best avenue. Get the well water analyzed and treat accordingly. We have sulfur dioxide here as well and we treat our water accordingly. I just happen to inject H2O2 in the raw water which precipitates out the sulfur and turns it into a solid which I filter out but I don't ascribe to homeowner grade filtration either. I use an industrial sized Cumo filter that takes industrial sized elements I buy wholesale and one element lasts a couple months.
Neither here nor there as your situation may be different but the important thing is get the raw water tested, see exactly what is in it and proceed from there and IMO only, RO units are a waste of money. Easier to purchase bottled water and a heck of a lot cheaper to boot.
Ive had an ro filter under kit sink for 15+ years. I swap out filters every 2 years. The unit included a selftest indicator thattells when to change filters. There not that expensive. That water is only used for drinking. Bottled water in some cases simply comes out of a tap. Some out of artesian wells. Your guess is as good as anyones. And now look at microplastic issues with bottled water.
Don't use your pool water. It is not sanitary, and has a bunch of extra chemicals that you won't want in your drinking water.
I think first things first. Get your water tested, and then move onto what the next step is. In some counties, it is even free, but even if it isn't, it is cheap to test for coliform (generic standing for bacteria), TDS (total dissolved solids, e.g. hard water), metals (iron, manganese, lead...) and pH. Try to get a sample as close to the well as possible and let it run for a few minutes so your sample is accurate for your water, not whatever is sitting in the pipes.
I had some samples taken, one of them cost $300. I am going to see if the guy has the results yet. He told me TDS was like 1200 and pH was off and there was a lot of sodium and it was positive for bacteria. I know there is more data, I will get it.
Once you have that information, I think you are in a better position to plan out your water treatment needs, and technologies.
A few related questions, if I may;
How deep is your well?
Not sure but "really really deep" according to my neighbor was here when they drilled it.
What is your well casing made of?
no idea. 6" PVC comes out of the ground.
What are your existing pipes? Galvanized?
No galvanized pipes. Everything was copper or PVC when I moved in and as the copper pipes start leaking I am replacing with PEX
Do you have any pretreatment on your well water that you are currently using?
water softener and filter are both bypassed.
All the best, Peter
thanks!
It shouldn't be, but it does happen. It is a very local issue due to local geology and practices, but definitely falls into my "trust, but verify" bin.
All the best,
Peter
There is a lot of oil operations going on the area for the past many decades and I have often wondered if it is related.
/ My well water is terrible. Should I just use pool water? #26
I think you need to get a well guy in there to tell you what you exactly have. Maybe send a camera down to see if your casing has been compromised. Find out how deep it is and have them test the water.
"no idea. 6" PVC comes out of the ground."
That sure doesn't sound like a good well to drink from to me. You owe it to your family.....money spent on clean water is well worth it.
I wonder if the copper pipe getting eaten by the water is the result of steel pipe not being isolated from the copper pipe. Or does the sediment carry the sand which basically sandpapers the inside of the copper pipe?
David from jax
There is no steel pipe and the copper pipe is lined with a hard layer of the black stuff which I think it would actually protect the pipe from abrasives. If it were an abrasive process eating the pipes I would expect the leaks to occur in the middle of bends. But so far all the leaks have been just randomly in the middle of a 10ft straight section of pipe. When I go to cut the pipe with the pipe cutter, it won't even cut. It just compresses. it's like the pipe is a soda can. Just a little stronger than a soda can. You can pinch it closed by hand if you're strong.
Why? What's wrong with that? Here's a picture in case my description was bad.
/ My well water is terrible. Should I just use pool water? #29
You are probably on the Chicot aquifer. It is apparently rather variable in water quality and dissolved solids levels (chloride and carbonate), apparently quite well and depth dependent. (USGS water quality data). In your part of the state, it is generally deep, but not that deep. (300' +/-, in contrast to a neighbor here that had to go down 700').
What kind of pipes do you have now? Galvanized?
Based on the USGS reports above, a guess is that your water might have a fair amount of chloride in it causing metal corrosion. Sediment filters might help with sand, but if you have carbonate as well, you might need a water softener, and then RO for drinking water.
Bottom line, I would get it tested and then you know what the issues are in the water.
All the best,
Peter
/ My well water is terrible. Should I just use pool water? #30
Your drinking water is one of your more important health concerns.
Don’t compromise by using pool water!
Pay to find out what exactly is eroding your copper pipes.
Pay to find out exactly what is causing your dark discharge stains.
You can only make an intelligent decision on your lifespan altering water consumption, by first getting to the facts of what you are actually dealing with.
/ My well water is terrible. Should I just use pool water? #32
That's an odd one.
There are many wells like that down south as they don't have the problem of freezing like we have. I still say have a well person look at it and have the water tested.
I have had it tested and I have had a well person look at it. Two different ones. I just am not confident with the solutions they have proposed because they're not much different than what I already have (water softener + inline filter), which is something I don't use because it isn't effective. I am going to have to pay $10k+ to get my whole house re-plumbed and I don't want to have to do it again in 20 years.
/ My well water is terrible. Should I just use pool water? #35
It sounds like they expect you to spend a bunch of money to clean up horrible "water" that you pump out of the ground. Maybe that is normal for your area... :unsure:...I don't know. It is normal to us have clean and cold water right at the well. I hope you are able to get that someday.
/ My well water is terrible. Should I just use pool water? #36
/ My well water is terrible. Should I just use pool water? #37
When you write the softener is not effective, what do you mean?
Our water softener didn't work well when we bought this place, and the water hardness was more than I expected. Come to find out that even though the softener went through its cycles regularly, the internal valve had shattered, so it wasn't actually softening water. 😡🤣. A new water softener and our water quality went way up.
I suspect that your water would benefit from putting the water softener back on line, (or, like us, a new one. We like ours. Hellenbrand) perhaps with new resin. That should soften the water, and remove some of the particles. With the right resins a softener can even remove some of the sulfates (if you have them) which with bacteria can make the water smell. Depending on which way the pH is off, a prefilter with the right elements or media should be able to address that. Copper does oxidize black under the right conditions. Again, it all depends on what is in your water.
Once the water has been softened, and with a sediment pre-filter, an RO filter should be able to clean things up. Our RO unit goes through a membrane every seven or eight years, just in case, and the pre-filters every six months or so. I do monitor the TDS going into and out of the RO u it to ensure that everything is working well. I would comment that we have a sediment filter at the well, store it in a tank, and then run it over a softener before the water gets to the RO, so particles/sediment are basically nonexistent.
That looks like a normal well head to me, check valve, pressure regulator and power, albeit one that has no frost protection...
As an aside, a water heater with gunk in the bottom is likely to burn out elements, and not be very efficient. It won't help with odors either.
All the best,
Peter
/ My well water is terrible. Should I just use pool water? #38
NEVER use pool wate! Make sure you have a plenty deep enough drilled well. Ours is 400 feet and is encased by a steel pipe that is 6 inches across, and works very nicely. We have been told that the water we draw is probably 1000 years old. We did have to install an iron bacteria filter and a water softener, however. We live way out in the sticks, and I can’t imagine some of that crap and corruption that you guys are talking about getting into your wells. Good luck to you!
/ My well water is terrible. Should I just use pool water? #39
Change (filter) frequency with any reverse osmosis system depends entirely on what is suspended in the raw water and your cade is most likely different than the norm. Once I precipitate the sulfur out of our well water, it's just fine for consumption and as a side benefit of the H2O2 injection, it renders the raw water devoid of any harmful cysts or contamination and we don't require an ion exchange system to 'soften' the water either. Hydrogen Peroxide injection at the proper dilution rate effectively renders the raw water inert.
/ My well water is terrible. Should I just use pool water? #40
I equate people not frequently draining the hot water heaters to not maintaining their tractors as well. I drain our HWH once a month to rid it of any solids or sediment that collects in the bottom and eventually leads to tank failure.
I also run a Pentair containment tank between the bladder tank and the industrial filter and the Pentair containment tank has a blow down valve at it's base to evacuate and of the precipitated sulfur dioxide that the H2O2 has precipitated to a solid. None the less, the HWH tank gets a partial drain monthly.
Been doing this for over 35 years now, employing 35% H2O2 injected with a Pulsa-Feeder commercial injection pump. I inject the H2O2 upstream of even the bladder tank to insure the longest amount of total dwell time. Every county test of our water yields nothing, just water and I have it tested yearly because of where the farm is located and the amount of herbicides and pesticides used around here that could contaminate our well water.
Every situation is unique however.
excavator trenching bucket- one bucket per lot (A61307)
excavator...
Compressor (A55973)
Compressor (A55973)
2011 Kenworth W900 Tri-Axle Sleeper Cab Truck Tractor (A60352)
2011 Kenworth W900...
2012 SOUTHERN VAC 130 BBL STEEL VACUUM TRAILER (A60736)
2012 SOUTHERN VAC...
24in excavator tooth bucket (A61307)
24in excavator...
WBrock Meyer 2000S 70'x12' 2000 BPH Grain Dryer W/Legs&Mill Discharge Sylo,Controller is included (A57148)
WBrock Meyer 2000S...
