Pat's Easy Change Extended top link?
/ Extended top link? #1
BellyUpFish
Florence, Al
Massey 4243
Planning on going with Pats for my MF 4243, but I’ve seen where several people talk about needing a longer toplink.
I’m also going to be going with a hydraulic toplink.
My current toplink is 26” closed. I can’t find a 30” toplink to make up for the additional distance from the Pats.
Anyone here gone to Pat’s and not had to change top link length?
/ Extended top link? #3
I use the factory 3rd link on my Cat 1 tractor, have never needed to change it out but it's not hydraulic.
/ Extended top link? #5
I think what you will find is that people with just cat 1 tractors are relatively happy with them. Then with the cat 1-2 tractor sizes people start having issues of one kind or another.
People with straight cat 2 have the most issues and the bigger the cat 2 capabilities,
(5000lb and up) the worse the issues get.
Good luck. ;)
Good luck. ;)
Good to know. I'll see what I can find.
/ Extended top link? #7
That's interesting. I haven't seen anything negative comments on them,
Can't speak to CAT 2 as I have the CAT 1 Pat's.. I have no complaint hooking and working those. Yep, the 4" or so was added in length. PTO shafts were fine... Top Link was fine and still original. It is manual - not hydraulic.
Pat's saves time changing implements...
/ Extended top link? #8
I just put the Pat's Quick Hitch (category 2 tractor with category 1 implements) on my Kubota MX5400. I use the Summit Hydraulic top link that has a maximum extension of 32", which like others have experienced, is not quite long enough to hook up some implements. I had a Pat's system on my previous tractor, (Kubota L3301) and really like how it helped hook up implements and I'd like to figure out a way to make the Cat II version work on my MX5400.
I have a machinist friend and he can weld up an short extension bracket that I can insert between the tractor and the fixed end of the hydraulic cylinder. Has anyone tried that type of adaptation? Are there issues that I'm not considering that would make that a bad idea? The bracket only needs to extend the top link a couple inches at most to solve the geometry issue created by the 4" extension that the Pat's Hitch adds to the lower lift arms.
/ Extended top link? #9
OP here: My buddy made a bracket similar to one I saw in another thread which I can't now find. Here's a picture of how it came out. The bracket moved the pin location out from the tractor about 3" and it solves the hook up issue nicely.
/ Extended top link? #10
Nicely done... (sounds like you need to update your profile! L3301 to MX5400?)
/ Extended top link? #11
I got a set of Pats cat 2 for my m6040 and on the whole like the way they simplify hook up although they can be a little tricky on some attachments. My PTO shaft is maxed out as is my top link when hooked to the winch so I have to be careful where I set the winch down when skidding logs.
/ Extended top link? #12
Pats Cat 2 here. 4" extension was simple to make. Completely removeable.
2020 CATERPILLAR 316FL EXCAVTOR (A65053)
2020 CATERPILLAR...
2016 JLG 800AJ 4x4 80ft Articulating Boom Lift (A64553)
2016 JLG 800AJ 4x4...
2002 Mitsubishi Lancer Sedan (A64557)
2002 Mitsubishi...
2018 CHEVROLET EXPRESS 3500 4X2 S/A 12FT  BOX TRUCK (A67148)
2018 CHEVROLET...
2000 Chevrolet Astro Passenger Van (A64194)
2000 Chevrolet...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
