HP increase module? Deere 3038e
/ HP increase module? Deere 3038e #62
I think some here are forgetting what’s being discussed is bumping up power of a large displacement, low performance 1.5 liter engine, rated at 37hp. It’s a 25hp/liter engine design….
Imagine buying a new 1.5 liter engine car with 37hp. All this talk of melted exhaust valves and such…😂
/ HP increase module? Deere 3038e #63
I own a 2014 LS XR4046 and got a nice bump in power after I deleted emissions and ECU control BUT my engine has mechanical pump and injectors, it wouldn't work with electric injectors.
/ HP increase module? Deere 3038e #64
Adding HP won’t make the loader lift anymore weight.
With that size and weight of tractor you would probably notice the ponies doing PTO work but doubt would benefit for ground engagement type work.
Agree, the Deere is one light tractor. I bumped up the power a bit on my L39, but it is weighted to 8,000 lbs.
/ HP increase module? Deere 3038e #65
I'm trying to explain from my recliner, I'm not at the tractor or paper manual in hand...so I called them. 812-618-9166
The tech said at end of the fuel rail is a pressure sensor. I unplugged it and module leads now go between the two. What it does is increases pressure as needed. They said simply call that number if anyone has any questions.
I told him I can now work at a lower rpm in 4WD and it won't spin tires, it just has more torque and he said that's exactly right.
More hp & efficiency means more power and less fuel used (efficiency).
Any questions simply call the company. All I know is it's money well spent and I'm happy with 30% more power.
"Increases pressure" that equals more fuel into cylinders within the same time period/injector cycle.
That pretty much shoots down the better fuel economy statement.
Why not give them a call? You could explain that to them so no more false advertising.
/ HP increase module? Deere 3038e #67
Front end loaders; turning the pressure up on the hydraulic pump, putting bigger cylinders on it will increase the lifting capacity but may well overload the loader frame, lift arms, and the front axle of your tractor. Then what? Increasing the power (hp) of a motor is easy with aftermarket gimmicks. If you want to see what can happen to a motor by increasing performance, watch the drag races some weekend. Marvel at the performance those guys get from passenger car motors until they explode. Thats not to say upping the horsepower a few clicks will blow a tractor motor or using premium gas instead of regular. How simple and cost effective is it to just get the machine that matches your job?
/ HP increase module? Deere 3038e #68
What fun is there in that? Besides that, some people want a newer tractor with no emissions and then make it a little more powerful.
/ HP increase module? Deere 3038e #69
I think the OP has a ways to go before he hits any performance/durability limits.
Here, hold my beer.🍺
Wife & I never watched drag races because we were too busy racing our cars. I've never blown a motor ever. My thought is whenever a manufacturer gives the weight limit it's not at it's maximum limit, not like if it's rated for 1800 lbs. it breaks at 1810 lbs.
If I can work the tractor at 1700 rpm instead of 2700 rpm, not spinning the tires getting the job done if anything engine will probably last longer.
Any questions...call the company that designed it. If installing that module causes engine damage how can they stay in business?
/ HP increase module? Deere 3038e #71
When you were racing your cars, did they develop 11,000 hp and do a 1/4 in less than 4 seconds?
/ HP increase module? Deere 3038e #72
If he can get 11,000 hp out of a 1.5 L diesel, I'll sign uo to be a sponsor!
No
Wife ran bracket, low 11's. SS/B me, 8.90's best.
Apples & eggs comparison. Anyone afraid of boosting power a bit it's simple: don't do it!
/ HP increase module? Deere 3038e #74
It always cracks me up the guys who worry so much about tweaking anything from factory specs. I mean we get it, you're skeered you will break something you can't fix. I usually have the attitude that I can fix anything I can break...
/ HP increase module? Deere 3038e #76
No need, that is simple hydraulics flow. Ask any firefighter about hydraulics flow.
/ HP increase module? Deere 3038e #77
I understand...but $600 vs $50K when you just need a little more power?
All other components are designed to reliably withstand XX HP, what do you think XXX HP will do to those components?
However in the end it's your equipment and money and decision.
/ HP increase module? Deere 3038e #78
I don't understand your confusion.
My bush hog recommended rpm is 550. For that to happen the engine must run whatever rpm gives 550 PTO rpm. If engine is at 1,600 rpm that gives 550 PTO rpm.
It's an example...I'm not at the tractor to verify 100%...but close.
This year bush hogging I won't have engine bog or rpm drops which is my concern.
The solution to your scenario is to drop down a gear.
/ HP increase module? Deere 3038e #79
Hydrostatic so only low & high. I use low range for about everything. Sure is nice having extra HP and also seems less fuel use as well.
2008 FOREST RIVER CARDINAL 30RK 5TH WHEEL (A65643)
2008 FOREST RIVER...
AGT Top Cat Brush Cutter (A64047)
AGT Top Cat Brush...
PREVIEW DATES AND TIMES (A65583)
PREVIEW DATES AND...
International Harvester (IH) 130 Manure Spreader (A66408)
International...
2002 CATERPILLAR 963C CRAWLER LOADER (A65053)
2002 CATERPILLAR...
2008 Ledwell LW48HTHT2 48ft. 40 Ton Hydratail T/A Step Deck Trailer (A64194)
2008 Ledwell...
