2manyrocks
Super Member
- Joined
- Jul 28, 2007
- Messages
- 9,623
When the soil is still wet in the Spring, sometimes you can pull most of the root without taking much soil. Also easiest pull…unlike dry conditions where the root wants to stay put.
That’s one reason. But if l had a lot of this type of removal, it would be worth it to me to avoid getting on and off the tractor if working as a single.The Brush Grubber costs substantially less for starters
Possibly. But the examples of use for the chain method in regard to disturbance, seems mitigated by how small the sapling root system is.Maybe there isn't enough room to get the tractor in the area and you don't want to disturb surrounding trees?
I made one of these also. Foolproof, cheap, and easy to make!View attachment 2994026
Hard to beat a chain and piece of pipe. Often use pipes on both ends of chain. Pipe bites the tree. If small trees are close, can pull several at a time. Easy to undo after pulling. Tried a grabber but didn’t work as well for me.
Spring cleaning around pastures and roads now before leafing out. Pulling encroachment trees, breaking off overhanging limbs and hauling off with Danuser Intimdator is pretty much hands free. A few trees and limbs will need to be polesaw cut.
These root systems of this type of flora seem so tiny to me that it isn’t so much of hole being dug as much as it is a sweep with the bucket down just a bit to dislodge the sapling.Just pulling the small trees roots instead of digging an unnecessary larger hole, easy to carry pipe and chain, no risk to loader arms
I saw a great video on YouTube of a guy pulling out stumps with a foundry hook. I bought a couple on Ebay but haven't tried it. He had a heavy chain and was pulling with a small cat (D4 or D2).Seems as though I have a ton of weed tree saplings that are too small for the chainsaw but large enough to yank out so I ordered the 'Brush grubber.. Anyone use one? Do they hold up? Gonna use it behind one of my M9's on the drawbar to yank them out. Got the 'heavy duty' model. Is it heavy duty enough for my 8K pound, 90 horse FWA Kubota or will I destroy it?
When I was young, I did the hooking for my dad. Some of hid grubbing hooks used old frayed cable that poked holes in my hands...not fun.My wife will do the hooking for me...lol
Do you use this on your FEL, Backhoe or 3pt? What works best to use the chain/pipe? Great idea!View attachment 2994026
I read that someplace was reviving a historical railroad and the only complete, running steam engine they could buy came from China, brand new, nobody else makes them any more.You can post 'China' on here without fear of retribution....lol
<snipped>
Interesting side note.. When they refurbished the Big Boy steam locomotive, the feedwater pumps were shot and they had to buy them from China of all places. Probably rolling on Chinese made roller bearings too.
Nice photos, many thanksThe BG-20 is the one I had, worked great on tree roots:
And small stumps chained to the front SSQA:
Also, most of my problem saplings/brush have grown up because they're too close to nice trees to bush hog. Their roots are entwined with the good tree's roots. Pulling them out by their trunks is my best option.Maybe there isn't enough room to get the tractor in the area and you don't want to disturb surrounding trees?
Original Brush Grubber did not work for me. It just slid up the tree while skinning the bark.Seems as though I have a ton of weed tree saplings that are too small for the chainsaw but large enough to yank out so I ordered the 'Brush grubber.. Anyone use one? Do they hold up? Gonna use it behind one of my M9's on the drawbar to yank them out. Got the 'heavy duty' model. Is it heavy duty enough for my 8K pound, 90 horse FWA Kubota or will I destroy it?
Unless you have lockers on the front and rear axles, 4 wheel drive is a misnomer. It's still 2 wheel drive but one in the front and one in the rear.I pull little **** with the grab hooks on the bucket - stuff like scotch broom or blackberry knots, or t-posts; probably 200-300# pulling force at the most.
Medium stuff I go through the loop in the middle of the bucket; really tough stuff I bring the A-frame out and either pull that with a chain to the tractor draw bar or I use my truck winch, with the truck anchored to a tree (it really doesn't take much to skid an unanchored truck!).
WTB 4-wheel parking brake; I guess putting the truck in 4wd gets you 3+....
I used the FEL on my JD Loader on a JD 5310 (62 hp). Now 10 hears after I bought it and 25 years after it was made I need to rebuild my cylinders on the FEL. That is probably abuse but I would think anything under 3" would be fodders for 90hp? It wouldn't bother me to back over them with a box blade. Note that I am no expert. I used a chain on the FEL to pull T-Posts. The on and off was not fun. Occasionally, the chain slipped off but practice with the wrap technique helped.Seems as though I have a ton of weed tree saplings that are too small for the chainsaw but large enough to yank out so I ordered the 'Brush grubber.. Anyone use one? Do they hold up? Gonna use it behind one of my M9's on the drawbar to yank them out. Got the 'heavy duty' model. Is it heavy duty enough for my 8K pound, 90 horse FWA Kubota or will I destroy it?
