Carl_NH
Elite Member
- Joined
- Apr 5, 2002
- Messages
- 4,280
- Location
- Coastal NH
- Tractor
- 01 Kubota B21TLB, 2010 Ferris 52" ZTR, Cub Cadet 1811, Gravely Super8
Yes that Lenz would work - you want 10 or 15 GPM flow rate at least, and the filter should go in the return line to the tank - most of these minis have a hyd cooler as part of, or possibly separate from the radiator. Most take the line going into the radiator and move to the filter inlet, then the outlet goes into the radiator.
Suggest you contact Kymron on this too and on the pilot filter as they may already have this set up or can point you in the correct direction.
