Recommendation for 3-point forks
/ Recommendation for 3-point forks #21
My rear forks are Rankin.
3-Point Fork
Heavy made, good welds, and nicely finished... handles my 32 wood pods well. Quik-tach ready. Prolly not the cheapest.
/ Recommendation for 3-point forks #22
That carryall frame from Tractor Supply was one of my top attachments. I purchased Pats quick hitch, and you can do so many different things. The only thing using a trailer hitch does travel around a lot of side to side, Play within the three point. I have rear pallet forks, and I don’t use them that much, they are a lot of trouble and heavy.
/ Recommendation for 3-point forks #23
/ Recommendation for 3-point forks #24
I just had a set of these delivered last week. Haven't had a chance to use them yet.
Looking at the product page...
What application would call for additional suit case weights on a set of front end forks?
I can't imagine...
/ Recommendation for 3-point forks #25
I can't imagine...
When you have the forks mounted on the front and want to lift heavy items on the 3-pt.
/ Recommendation for 3-point forks #26
I was moving a stock panel with my former L3200 years ago. Pallet forks + the 100, maybe 200lbs panel. In 2wd & went down the slope behind the barn. Cut to some panic with the go pedal & brakes not doing anything & some pallet forks sized holes in the tin.
Always have an implement on your 3pt when using the loader folks. Otherwise the rears won't have enough traction. If the rears don't have enough traction, you are also putting excessive stress on your front axle. Putting it in 4wd would have gotten me traction, but still put excessive weight on the front axle
/ Recommendation for 3-point forks #27
I saw a SSQA fork mount, which had the tabs on it to attach to the 3-point hitch. Can remember who was selling it.
2022 BOBCAT T66 R-SERIES SKID STEER (A65053)
2022 BOBCAT T66...
More info coming soon (A61574)
More info coming...
JMR 72in Dual Cylinder Grapple Rake Skid Steer Attachment (A64553)
JMR 72in Dual...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2022 EZ-GO ELITE...
1987 Polar 307 SS 3 Comp SS Insulated T/A Chemical Tanker Trailer (A64194)
1987 Polar 307 SS...
