Female Hydraulic Fitting Won't Lock On the Male Firring
   / Female Hydraulic Fitting Won't Lock On the Male Firring #1
bsekf
Gold Member
WNY
Kubota 7030, Long Landtrac 4700, Mahindra 5155
Almost new tractor and I don't believe the remotes have even been used. Went to hook them up and one female won't accept the male fitting. One works just as it is supposed to but the other one you can't get the male into it far enough for the detent balls to engage. It is definitely that female fitting because both males will work in the other female. Is there a fix short of a new fitting?
   / Female Hydraulic Fitting Won't Lock On the Male Firring #3
What ptsg said......
Did that.
   / Female Hydraulic Fitting Won't Lock On the Male Firring #5
Try soaking the balls and ring with a good penetrant like Kriol, PB Blaster, or Fluid Film.
With the ring pulled back (or pushed forwards depending on the style) can you move the balls?
   / Female Hydraulic Fitting Won't Lock On the Male Firring #6
Can you depress the ball or poppet in the male fitting? Possible wrap in a rag and then tap it on something metal to see if there is still a little trapped pressure in the hose. Some styles of quick disconnect it does not take much pressure to make them impossible to connect.
   / Female Hydraulic Fitting Won't Lock On the Male Firring #7
He wrote that both males work in the other female QD.
The tractor has been sitting outside in below freezing weather, so I am going to put the heat gun (hair dryer) on the fitting and try to warm it up, I'll check the detent balls but I think they moved. Thank all you guys.
   / Female Hydraulic Fitting Won't Lock On the Male Firring #10
Start the tractor up and warm up your hydraulic fluid as well.
Before you start messing with fittings, don't forget to relieve pressure by putting fel in float mode and also press in the little button on your shift lever.
   / Female Hydraulic Fitting Won't Lock On the Male Firring #11
May have to loosen the connector to bleed a little fluid. Messy, but sometimes that is my only way to relieve the pressure
   / Female Hydraulic Fitting Won't Lock On the Male Firring #12
Not Fluid Film Kenny. FF has no value as a penetrant. FF is more of a corrosion protector and I use it as such. It's lanolin based.
   / Female Hydraulic Fitting Won't Lock On the Male Firring #13
Mine are the style that the ring pushes in when connecting. One of them, I always have to use a screwdriver to push the ring in when connecting.
This minor inconvenience is better than spending $70 for a new replacement.
Brute force and awkwardness won again. I got a heat gun and got it good and hot and sprayed it with PB Blaster and my penetrating oil and put one of the new males on a piece of pipe and hit it with a hammer and it snapped right in. No idea what the problem was, just new I guess. It works now!
   / Female Hydraulic Fitting Won't Lock On the Male Firring #15
Stubbornness does overcome 😁
378721 (A54865)
378721 (A54865)
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2019 INTERNATIONAL...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2017 JOHN DEERE 323E SKID STEER (A60429)
2017 JOHN DEERE...
Adams Tender / Magnolia Trailer (A56438)
Adams Tender /...
2019 KOMATSU D65WX-18 CRAWLER DOZER (A60429)
2019 KOMATSU...
