Female Hydraulic Fitting Won't Lock On the Male Firring
   / Female Hydraulic Fitting Won't Lock On the Male Firring #11
May have to loosen the connector to bleed a little fluid. Messy, but sometimes that is my only way to relieve the pressure
   / Female Hydraulic Fitting Won't Lock On the Male Firring #12
Try soaking the balls and ring with a good penetrant like Kriol, PB Blaster, or Fluid Film.
With the ring pulled back (or pushed forwards depending on the style) can you move the balls?
Not Fluid Film Kenny. FF has no value as a penetrant. FF is more of a corrosion protector and I use it as such. It's lanolin based.
   / Female Hydraulic Fitting Won't Lock On the Male Firring #13
Mine are the style that the ring pushes in when connecting. One of them, I always have to use a screwdriver to push the ring in when connecting.
This minor inconvenience is better than spending $70 for a new replacement.
Brute force and awkwardness won again. I got a heat gun and got it good and hot and sprayed it with PB Blaster and my penetrating oil and put one of the new males on a piece of pipe and hit it with a hammer and it snapped right in. No idea what the problem was, just new I guess. It works now!
   / Female Hydraulic Fitting Won't Lock On the Male Firring #15
Stubbornness does overcome 😁
Craftsman 917.257632 42in Riding Mower (A51694)
Craftsman...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
(APPROX 100) UNUSED FUTURE 10' GALVALUME STEEL (A51248)
(APPROX 100)...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A51248)
UNUSED WOLVERINE...
