Female Hydraulic Fitting Won't Lock On the Male Firring
   / Female Hydraulic Fitting Won't Lock On the Male Firring #11
May have to loosen the connector to bleed a little fluid. Messy, but sometimes that is my only way to relieve the pressure
   / Female Hydraulic Fitting Won't Lock On the Male Firring #12
Try soaking the balls and ring with a good penetrant like Kriol, PB Blaster, or Fluid Film.
With the ring pulled back (or pushed forwards depending on the style) can you move the balls?
Not Fluid Film Kenny. FF has no value as a penetrant. FF is more of a corrosion protector and I use it as such. It's lanolin based.
   / Female Hydraulic Fitting Won't Lock On the Male Firring #13
Mine are the style that the ring pushes in when connecting. One of them, I always have to use a screwdriver to push the ring in when connecting.
This minor inconvenience is better than spending $70 for a new replacement.
Brute force and awkwardness won again. I got a heat gun and got it good and hot and sprayed it with PB Blaster and my penetrating oil and put one of the new males on a piece of pipe and hit it with a hammer and it snapped right in. No idea what the problem was, just new I guess. It works now!
   / Female Hydraulic Fitting Won't Lock On the Male Firring #15
Stubbornness does overcome 😁
1992 GROVE AP-308 CRANE CRANE (A53426)
1992 GROVE AP-308...
2009 Wells Cargo 5th Wheel Office Trailer (A53117)
2009 Wells Cargo...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
2009 Ford F-550 Auto Crane 4004EH Crane Service Truck (A51692)
2009 Ford F-550...
40' CONTAINER (A51248)
2012 Chevrolet Silverado 3500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
