Female Hydraulic Fitting Won't Lock On the Male Firring
   / Female Hydraulic Fitting Won't Lock On the Male Firring #11
May have to loosen the connector to bleed a little fluid. Messy, but sometimes that is my only way to relieve the pressure
   / Female Hydraulic Fitting Won't Lock On the Male Firring #12
Try soaking the balls and ring with a good penetrant like Kriol, PB Blaster, or Fluid Film.
With the ring pulled back (or pushed forwards depending on the style) can you move the balls?
Not Fluid Film Kenny. FF has no value as a penetrant. FF is more of a corrosion protector and I use it as such. It's lanolin based.
   / Female Hydraulic Fitting Won't Lock On the Male Firring #13
Mine are the style that the ring pushes in when connecting. One of them, I always have to use a screwdriver to push the ring in when connecting.
This minor inconvenience is better than spending $70 for a new replacement.
Brute force and awkwardness won again. I got a heat gun and got it good and hot and sprayed it with PB Blaster and my penetrating oil and put one of the new males on a piece of pipe and hit it with a hammer and it snapped right in. No idea what the problem was, just new I guess. It works now!
   / Female Hydraulic Fitting Won't Lock On the Male Firring #15
Stubbornness does overcome 😁
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A51248)
UNUSED WOLVERINE...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
2018 INTERNATIONAL LT625 (A53843)
2018 INTERNATIONAL...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A51247)
UNUSED CFG...
MARS AIR DOORS TAN BANK (A51248)
MARS AIR DOORS TAN...
