Using snow blade with rubber edge
/ Using snow blade with rubber edge #21
Here is a picture of my rear blade. I’ve got a fairly low dollar piece of metal on mine to sandwich it. I intended to use the original cutting edge sandwich it but the yellow edge wasn’t tall enough.
/ Using snow blade with rubber edge #22
Turn the blade around because its in dig mode. But if you have asphalt, this is the only way I go after trying a rake, blower, plow, and pusher on my1070. This unit on my 1435 easily does 10 inches at a good clip. Nothing left behind to freeze. Sometimes I will make a second pass if a vehicle has already packed down tracks. I even use it to make paths around the back fields for my dog walks. (I ride a golf cart: they are NOT snow vehicles.)
/ Using snow blade with rubber edge #23
I've been looking for a 3 point broom for some time now to round out my set of snow removal tools. I've never used one, but videos show them working very well on snow.
/ Using snow blade with rubber edge #24
I prolly shouldn't admit it, but I've also used my front mowing deck at full power to remove snow. Works pretty well for a small amount. Raise the deck a bit. You have a zero turn....
2 BALE HAY SPEAR (A63291)
2 BALE HAY SPEAR...
2016 FONTAINE VELOCITY FLATBED SEMI TRAILER (A61568)
2016 FONTAINE...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2016 HAMM HDT90IVV DOUBLE DRUM ROLLER (A64279)
2016 HAMM HDT90IVV...
Unverferth 235 Seed Tender Wagon (A64047)
Unverferth 235...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2014 Ford F-150...
