Tarp Talk
/ Tarp Talk #1
bdhsfz6
Elite Member
Northeastern Pennsylvania
Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
Yeah, another post on tarps.
I no longer burn coal, so I don't have ash to spread on my steep 1.25 mile private road. Instead, I have anti skid material delivered in bulk. My question is, what kind of tarp would work best to cover the 20 ton pile? I've used many different tarps outdoors to cover various things in the past, but none last more than a couple of years exposed to sun & wind.
The plastic tarps, regardless of color or thickness, seem to break down under prolonged exposure to UV light. I've had the best luck with heavy duty paraffin treated canvas but they are expensive and getting harder to find. I'd also like something with a darker color to help keep the pile from freezing.
Anything new on the market? What do you all use?
I'm also going to have to figure a way to load the anti skid into a 48" wide hopper using a 72" FEL bucket.
/ Tarp Talk #2
You can get billboard advertising “tarps” for pretty cheap and they are big. They last a really long time.
/ Tarp Talk #4
I often get "Goodyear" or equivalent rubberized take off roofing to cover my items. Thick and lasts for years is in fairly narrow sheets, 10 foot or less unless bonded/seamed together. For my purposes the width does not bother me, for you probably too narrow.
/ Tarp Talk #5
I have some old rubber roofing, haven't used it yet, but dang it is extremely heavy. 1/4" thick, 10' wide and can't be more than 15' or so long. Changed the project I needed it for, now looking for a use. Need tractor to move it.
/ Tarp Talk #6
I like Haydukes idea. That stuff is thick and has a nice flexibility to it.
What about that 10mil reinforced plastic they use for crawl space damp proofing? It's pretty tough.
I really think the thing that kills tarps is that they are a woven material. Once they start to breakdown the integrity of their structure is compromised and it is all over. And because they are woven they make a mess as they degrade. I have a bunch of tarps covering some lumber piles temporarity until I can get them stacked well. Thank you for seeing the folly in this. I need to look for some of this billboard material. I bet FB marketplace has it. Gonna check now, will report back.
/ Tarp Talk #7
Prices are decent. Not much cheaper than a tarp of he same size but if they last 2 or 3 times as long it is a win
/ Tarp Talk #8
Have you tried heavy black visqueen? I bought a large roll at the local hardware (a "real" hardware store) Held up for years under/over a sand pile. Finally retrieved it after the old pile became overgrown and getting snagged by the bush hog.
BTW, what is anti-skid material?
/ Tarp Talk
Around here, quarries sell a mix of stone dust and 1/4" crushed stone and call it "anti skid".
I get a couple of tri axle loads every few years and need to cover the pile. 20' x 20' minimum.
  • Good Post
Reactions: jmc
/ Tarp Talk #10
Another cool thing about the PVC billboard tarps is they are customizable. They can be cut and glued using PVC cement. I have used this to make dry bags for rafting. People make really nice inflatable sleeping pads out of them They would make excellent covers for lots of things with a quick and easy cut and glue job.
I plan I getting bigger tarps and cutting them down to make the perfect sized temp top covers for my lumber stacks. I will double over the edges with PVC cement and then add grommets in strategic locations. Maybe reinforce corners that fold over the edges of my piles. For instance a tarp for a 4' wide stack of 2x4x10s make a tarp 6'wide by 13 or 14' long so there is just enough overhang to protect the wood from most rain. The next goal would be to develop an easy solution to secure these tarps. Thinking maybe corner grommets with paracord to throw a quick truckers hitch around the pallet.
/ Tarp Talk #11
So I found a good source of PVC tarp material on Market place. It was only about 50 minute drive. These folks have a hookup on end of rolls of unused PVC billboard material, so it is white on one side black on the other. The pices they get are about 16'x20' and they charge $20 each. That is 320 sqft for only $20, pretty good deal, especially for unused white pieces. I ended up buying 4 ~16x20s and they threw a smaller one in for free. This stuff in nice. The guy says these tarps easily last 10 years in the elements full time. I can't wait to make some nice tarps by folding and gluing a 1.5" edge and adding grommets.
2013 Lincoln MKZ Sedan (A61569)
2013 Lincoln MKZ...
2016 Volkswagen Jetta Sedan (A61569)
2016 Volkswagen...
SANY SY35U EXCAVATOR (A63276)
SANY SY35U...
Patterson water pump (A59230)
Patterson water...
2013 Ford Taurus Sedan (A61569)
2013 Ford Taurus...
1990 20ft Center Console Fishing Boat with 21ft. T/A Boat Trailer (A61569)
1990 20ft Center...
