2025 Ram trucks
/ 2025 Ram trucks #81
The other great thing about in-line six configurations is they are cheaper to build/buy & maintain.
Inline engines do require a simpler block boring line, with only one row of cylinders.
They get better fuel economy
The examples you know best, might get, but thats not Newtons law. A lot of design factors are involved. Many heavy industrial engines are V configurations.
Their crankshaft is stronger because its supported by more bearings
In a V engine, the same crankpin never gets loaded at the same time by two cylinders. When the left bank cylinder makes compression and power stroke, with maximum piston pressure, the right bank cylinder is making intake and exhaust stroke, where the crank pin only accelerates and decelerates the piston at TDC and BDC.
The spacing between the main bearings usually doesnt differ from an inline configuration (Cummins KTA19 inline 6 and KTA38 V12) they are just staggered the width of a connecting rod bearing...
What matters is if the designers can put enough bearing surface in a given space to get to the required PSI of bearing load.
Cat doesnt seem to have an issue achieving that with the 3516 V16 engine found in their biggest mining equipment..
/ 2025 Ram trucks #82
And thats a good thing. Reduces wear & fuel consumption.
Let’s roll back to the 2025 ram, shall we?
No more CP3? "New version" CP4... I certainly Hope so, especially when the trucks are out of warranty.
Why?? Maybe it is Not really a CP4 some sources are saying a completely different CP8? new design pump?
Not sure Glow plugs are better than a grid heater either, more failure points.
/ 2025 Ram trucks #83
Since all of us basically run smaller OTR trucks and tractors, why don’t we keep the diesel engines limited to 25-500HP and under 15L in size?
We all know battleships and tugboats and huge mining equipment can have V configuration diesels, but perhaps we keep it to the other 99.5% of the equipment TBN’ers own/operate?
Just keeps the conversation practical and more useful to this group here.
The V-8s and in line six engines on TBN generally run 25-500HP and under 15L in size. Agree????
/ 2025 Ram trucks #84
Most important reason that the common idea is that long stroke means more low end torque, is because in naturally aspirated, 2 valves per cylinder engines, the valve diameter limits high rpm breathing on an undersquare engine vs an equal capacity oversquare engine, just because you can put larger diameter valves in a head atop a larger bore engine.
Glass half empty, or full?😀
What you are describing is a cause of an under-square engine having low torque at higher rpm’s (hp) , not a cause of higher torque at low rpm’s.
For a given engine displacement, the long crank throw’s mechanical leverage , is what directly gives a longer piston stroke its inherent ability of higher rotational torque.
/ 2025 Ram trucks #85
You have one mode...
Well, no. Not necessarily. Up until 2023, I had (2) Powerstroke V8’s.
So no, actually not one mode…..
I can speak about both. I also owned a dozen other Powerstroke V-8’s and 1 duramax V-8.
In line six pulls harder with less RPM. That makes it a better pulling/towing truck.
And it gets better fuel economy while doing so.
/ 2025 Ram trucks #86
In general, Industrial diesels are advertised as having good torque backup, which means how much the torque increases when rpms drop. Torque backup percentage is always relative to the torque it makes at nominal rpm. So i stuck to the industry standard of relating peak torque to the max torque at nominal rpm. Engines like the European IH DT402 were praised for their low end torque, while the restrictive head on this 100x140mm engine just acted as a turbo wastegate before a wastegate became commonplace.
Contrary to popular belief, the smaller piston surface on which combustion pressure is excerted, fully cancels out that extra mechanical leverage. Its all about how much valve you can stuff above a certain bore size.
Off course cam timing and turbocharging make a far greater difference in this day and age, but in the 80s it was all about valve and intake tract size.
A slightly oversquare engine does hold the better cards when designing for thermal efficiency, because of the increase in combustion room surface when the piston gets bigger. The highest temperatures occur in the top quarter of stroke, and diminishing the piston and head surface exposed to it, reduce thermal loss and increase efficiency... adding a millimeter of piston to head clearance gives far less heat absorbing surface than if the same volume of compression volume is created with 10mm more bore...
/ 2025 Ram trucks #87
When it comes to the “big 3” diesels (Powerstroke, Cummins, or duramax/Isuzu) in US pickups, I’d give Cummins the nod for a much greater capability and world renowned reputation as one of the top diesel engine manufacturers in the world. Isuzu is very good, too.
The vast majority of their designs are in-line.
/ 2025 Ram trucks #88
Lower rpm means lower friction losses. Piston rings are the main cause of friction losses in an engine. Thats why the NT855 obsoleted the V903 in the 70s... it just had the better cards for cruising fuel efficient at low rpm on the interstate. When you dont have to use a fast camshaft to get peak hp at 2800rpm without a turbo, you can use a cam timing for torque and fuel efficiency at lower rpm cruising speeds and increase power density with a turbo (which also spools up easier with a cam designed for low end torque)
/ 2025 Ram trucks #89
Have had diesels in my cars for 22 years. Never had a glow plug break, nor heard of a glow plug dropping into the cylinder.
I do hear Gale Banks talk about ruining an engine when the grid heater bolt rots off and destroys a piston... i never heard of any other engine with this failure point, ever..
/ 2025 Ram trucks #90
It’s not just “a popular belief “ , it’s a Physics fact.
Your “Smaller piston fully cancels out the extra mechanical leverage “ ..No idea where you came up with that one, but if one was to believe it at face value, then there’s no torque advantage to design a longer stroke engine.
Large valve size isn’t a big factor until you’re higher in rpm’s, or under high turbo pressures
/ 2025 Ram trucks #91
It’s not “a popular belief “ , it’s a Physics fact.
It is a fact, if your piston bore remained the same.
However, if displacement stays the same (meaning a bigger piston diameter at the shorter stroke) and mean combustion pressure stays the same, they cancel each other out.
Thats a fact, yes... Just do the math, if displacement, combustion pressure, rpm, cam timing and lobe shape remain the same, the math doesnt just get another outcome if you change bore and stroke ratio... unless other minor design factors are involved that prevent such engine from achieving the same mean combustion pressure, namely cylinder fill rates, determined by intake tract resistance and valve timing...
Shorter stroke engines however, can make more rpm with the same piston speed, thereby making more power with the same displacement. Therefor, cams of short stroke engines are generally tuned to improve high rpm breathing while loosing bottom end torque, while popular belief thinks its just the stroke causing this. Basic engine explanations that are common, when attributing secondary design characteristics of long stroke and short stroke engines to stroke itself, are grossly oversimplified: there is no causal connection between them 😅
Indeed, there isnt in this day and age. There is a thermal effeciency advantage because the combustion room surface area at or near TDC is smaller with a smaller bore and the same compressed volume.
Piston speed and combustion room surface area are what drives industrial engine design into oversquare engines with a 1 to 1.2 to 1.3 bore stroke ratio in heavy industrial engines.
In automotive engines, weight is a bigger factor and longevity less, so the consensus is undersquare engines that operate at high rpm when accelerating fast, and drop a few 1000 rpm when cruising.
/ 2025 Ram trucks #92
I just needed the KTA19 and KTA38 as an example of inline engines and their V derivates having the same piston spacing because i dont know any other engine family that exists in both V and inline versions.. though the same point applies to 15 to 500hp engines that TBN folks own/operate.
Oh wait, the Deutz FL514 range came in 3 to 12 cylinders. But i doubt TBN folks own/operate these oldies.. the F4L514 was Deutz first aircooled engine in 1944 developed for H'tlers war on the Eastern front in the Siberian cold...
/ 2025 Ram trucks #93
Gale Banks is in the business of selling upgrades, some of which may be a solution hunting for a problem, or being sold as potential failures more common than they really are.
/ 2025 Ram trucks #94
I have a pretty trustworthy tech who only works on Ram diesel trucks at one of the largest Ram dealer on the east coast
He said he’s seen zero trucks have this failure.
Let’s hope it stays that way.
Also would think there’d be a recall if it was a serious problem? After-all it takes little effort to resolve.
/ 2025 Ram trucks #95
My 2.5 TDI broke a camshaft, bending valves and a rod. I brought it to the garage a few days before because i heard my fuel pump timing was off around 1500rpm.. My garagist had heard of the problem, but never thought of it when i asked to check pump timing (driven from the other end of the camshaft) but when it happens after 390.000km and 12 years, a manufacturer wont recall it.
My later 2.5TDI i drove to 560.000km before a pulse giver disk on the crankshaft came loose, breaking my crank position sensor which was no longer available from VW. The camshaft was fine !
Both failures occur at high mileage and infrequent so that these issues dont get recalled.
My mates Werklust WG18B loader has a Daf 620 engine. The truck versions had no issues, but the offroad version with a deep pan (able to work at 45 degree slopes), has a longer oil pickup tube whose support strut can come loose. Then the pickup tube itself can vibrate from the socket, engine starves from oil, and it throws a rod.
When you stick your finger in the bung you can feel the strainer and test if its solid. If not, the pan needs to be dropped and the strut reinforced and repaired. Theres plenty of time between strut failure and tube failure, so my previous employer never recalled these loaders, the service department just checked at every oil change.
Given what you guys tell me, this is a similar issue, that can simply be avoided by annual inspection of the bolt. Or simply replacement by a stainless bolt. The Cummins has no timing belt, but if it had, changeing this bolt every timing belt change would probably prevent this.
But i agree, its rather convenient for Banks that this solves a potential failure point... That will convince the wife that you really need this performance upgrade ! 🤣
/ 2025 Ram trucks #96
Noticed the concept 2026 RAM Dodge Grand Caravan RWD and a 5.7L Hemi. Also has a different hidden slider door track as well. Not a minivan, but a mid-size van. Not a full size RAM Van last seen in 2002.
Ram's CEO Tim Kuniskis wants a new van and it could be inspired by the best-selling Dodge Grand Caravan
/ 2025 Ram trucks #97
How well received is the ProMaster in the US ?
Selling the Dodge Sprinter made sense, but to me personally, the ProMaster will allways be a lowly Fiat Ducato with its chimpansee snout.
I assume this is a fake, but this snout already makes it more palatable;
The only US vehicle mass imported into Europe was the Dodge Caravan, or Chrysler Voyager as it was called here most of the years. They sold a bunch untill the crossover SUV came in fashion 10 years ago. Right now, i only see the Pacifica listed.
I just dont see a pickup truck based V8 RWD van being a replacement, its going to be more expensive and heavier.. ?
Its certainly not going to sell in Europe..
/ 2025 Ram trucks #98
Nope, it is for the North American market, plain and simple.
/ 2025 Ram trucks #100
That was 10 pages of wasted time....
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
2020 FREIGHTLINER M2 4X2 S/A 26FT CDL REQUIRED CURTAINSIDE BOX TRUCK (A67148)
2020 FREIGHTLINER...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
2016 Peterbilt 579 Wet Kit T/A Day Cab Truck Tractor (A64556)
2016 Peterbilt 579...
2018 GRASSHOPPER 900D MOWER (A66091)
2018 GRASSHOPPER...
2011 Kenworth T300 S/A 17ft. Cab and Chassis Truck (A64194)
2011 Kenworth T300...
