Chinese digger recommendations
/ Chinese digger recommendations #141
Hi Tex, I ordered on May 3rd, and it was delivered on June 12th, so it took 5 weeks. It really depends on the port of entry. I think they bring them into a port on the East Coast, too—NJ/NY, as our driver was from PA—and then, of course, on the West Coast, into Long Beach.
What I have seen is the orders in the west and your area average between 2-4 weeks and in the east 4-6 weeks. It depends if they have stock in CA or where the ship/container is in transit.
James Knight (who did the YT video) got his in like 10 days from order - he is in Oregon.
As to delivery, I got an email on June 12th at about 6:00 AM (I was traveling) stating that the shipping company would contact me about delivery.
Then at 7:30 AM 90 min later my wife called me and said there is a guy here with your Mini Excavator! He got it off the truck and drove it up the driveway and then brought the extra bucket and quick attach up. All told about 30-45 minutes and he went over everything with my wife too - could not have been nicer!
/ Chinese digger recommendations #142
Thx Carl! Wow, I hope I get as good a driver!
/ Chinese digger recommendations #143
I'm seeing a swing boom XIX for $11,115 and one without the swing boom for $10,069.95 on the eBay listings. So which one? I was looking at buying a mini ex with tracks because I have about 8 honey locust trees with huge thorns to remove. Plus I have some other tree debris to clean up. Would be nice to get the stumps out of the way, too.
/ Chinese digger recommendations #144
Yes you will see different prices the more you look through all the listings - they are all the same machine - Machinery Asia, USA Excavator etc, are Typhon as far as I know.
Usually they have a "best offer" option too, so don't be shy to put in an offer - and ask them to add in some attachments - quick connector, clean up bucket, trenching bucket and since you are doing stumps definitely get a ripper tooth. in other words offer them say 10K but with x attachments included.
Also I found their standard bucket 16" a bit too big for rough ground and rocks and the 8" trencher to be great for rocks etc.
/ Chinese digger recommendations #145
Yeah, the 16" is too big, but also the 8" is too small. And both are poorly made and won't last. Folks should try to get the buckets made for some of the 2T and bigger machines.
12-13" wide would be optimal, from my experience. Even that width bucket will get clogged at times.
/ Chinese digger recommendations #146
DF - could not agree more on the quality of the buckets and size - a 12" would be perfect. I bought 3/8" steel and reinforced them. Interesting that the tilting/grading buckets are more HD built than the digging buckets, and the rock/screening bucket is the weakest of all of them. Wish they would put good teeth on them too with top/bottom design like on most BH and excavators.
/ Chinese digger recommendations #147
As you may know, I tossed my OEM teeth right away and welded on my own. They have worked flawlessly, and are far easier to make than drilling holes in the bucket.
Teeth do not have to be long, as you see on most backhoe buckets. Plus, it would take hundreds of hours to wear out the ones I welded on, using plow-type steel.
If you don't like the short ones I did for my 18" Chinese mini-X bucket (posted in one on my threads), then you can do what I did for my backhoe attachment 17y ago (photo). It came with crappy cast teeth, too, so I made tooth holders and welded on off-the-shelf scarifier teeth. 200hr later they are rounded off, but still work great.
/ Chinese digger recommendations #148
Hi Guys - found this link to Bison Equipment in PA that buys and resell the Hightop and Vote machines as well a Seisan "commercial excavator" Home - Bison Equipment, Inc.
There are also many videos on these machines on the web site and a "weigh-in" of the Vote, Rippa, and Hightop "2 ton" machines.
- Vote VTW 18 (same as Terror XIX) 1406 KG or 3100Lbs w/o operator
- Hightop 18 (same as Terror XVIII) 1481 KG or 3260 Lbs w/o operator
- Rippa 322 - 1130KG or 2586 Lbs
The difference between the Vote and the Hightop is mostly due to the rear ballast or large weight on the back. Then with an operator they come close to 3600 lbs or 1.8 US tons.
/ Chinese digger recommendations #149
Interesting. I saw their site earlier but I didnt pick up on the similarities of their models to the Typhon XIX I ordered nor the actual weights. They say the VTW 18 has the 722 Kubota and mine is supposed to be the 902 (Lectura web-site says 902 is about 9kg (~20lbs) heavier than the 722 so that's helping to get it to the rated "operating weight"). Not sure if there are any other differences. I see the VTW is also quite a bit more expensive than what I paid. I guess its for the warranty and whatever prep they do.
/ Chinese digger recommendations #150
Yes - the XIX has the 902 and it is 16 HP vs 14HP of the 722. IMO, the XIX is the better machine in fit and finish and I suspect most of the weight is in the large counter weight on the XVIII.
His prices are higher but they have parts, and one of the better web sites for these mini's regarding content. I have seen postings on ebay to buy the XIX direct from China for $4700 BUT that does not include Duty, Customs Fees, Brokerage Fees and possibly delivery from the Port of entry. So these charges could add $3-4K or more, but that's the unknown. I am OK paying 1-2K more for delivery to my door and no surprises.
/ Chinese digger recommendations #151
I love those 2 Kubota DI diesel engines, even made in China. But, both the D722 (719cc) and D902 (898cc) 3-cyl engines may be specced for those outputs, but that's at 3600RPM (crazy-fast).
I don't know if the engine speed controls on these minis even LET you go that fast. More likely, they run at 2000-2500 RPM. At 2000 RPM, they put out 9 and 12hp, respectively.
The Kubota K008 uses the D722, and it is rated at 10.2hp because it is run at about 2100-2200 RPM.
If the Typhon or other units with either engine go much faster, please tell.
/ Chinese digger recommendations #153
From looking at the engine specs at the Kubota site, @3600 rpm the 902 is rated at 18.5kw(24.8hp)! My Typhon XIX manual lists the 902 with a rated power of 11.8kw (15.8hp)@2500rpm. The max torque is listed as 42.9nm@2000rpm. The Typhon data points don’t match the curves on the Kubota chart so I assume the minis are using a continuous duty-cycle rating. The curves Kubota supplies are an intermittent rating. Anyway, that torque translates to 9 kw(12hp) at that speed. I would expect that this might be a good speed setting for doing work with these things since, in a previous life, our HD on-highway diesels liked to operate at peak torque, which is usually close to best efficiency (lowest BSFC).
/ Chinese digger recommendations #154
Hydaulic Pump is the Key. It is not outright HP of the engine, it is what the Hydraulic Pump can produce at "X"RPM, and what power it takes to turn that pump at that speed. Oil Viscosity would also come into play.
Kind of why the mini Skid Steers with 12.5hp and 23hp Engines perform very simularly
/ Chinese digger recommendations #155
Ordinarily, I strongly prefer any diesel engine to a gas engine in a tractor. Don't really like the 20hp V twin gas engine in my Terramite backhoe for example. Seems to burn a lot of gas in a day.
Is a diesel really worth it to power these chinese mini excavators compared to the ones that have the small 13hp or so gas engines? I wouldn't think these smaller gas engines would burn much gas, but I'd think the little Kubota diesels would be highly fuel efficient and have excellent life time durability.
/ Chinese digger recommendations #156
Diesel is my preference, but its not all about the power plant - it's what's included in the diesel mini's. The small 1 ton gas don't get hyd cooling, have a single pump Then noise, heat, and gas use is higher.
The diesel has a bigger frame, heavier, longer tracks, run cooler etc,. Yes there is a cost but for the 5-6K more the diesel are worth it with the extra features included standard.
/ Chinese digger recommendations #157
Good point. The hp numbers I quoted above are off a Kubota engine spec chart.
I have harped on this point, but it bears repeating: Any of the Diesels (1, 2, or 3-cyl) seem happiest to operate at about 2000-2200 RPM, and the makers have usually sized the pumps to work at that speed (6.8cc/rev for the single pumps).
Transplanting a gas engine (420-440cc thumper, or V-twin GX clone) really needs to have a smaller pump installed. These engines are happiest at about 3000RPM, or a little higher.
/ Chinese digger recommendations #158
Is pump size relative to gas engine RPM one of the reasons for some of the gas units being so jerky in operation?
/ Chinese digger recommendations #159
Two reasons for jerkiness: Low weight, and flow rate too fast. Most gas 1-2T minis have too much flow at 3000 RPM, so reducing flow rate would help, yes.
Crappy valves without good "feathering ramps" could exacerbate jerkiness, but I have found (by taking them apart) that the valves are good quality in that area.
/ Chinese digger recommendations #160
Ok, I'm looking for an auger for the miniX that's supposed to be delivered tomorrow (I'd like to buy it before tariffs kick in). Problem is the dimensions at the attachment points are all over the map from the EBay/Alibaba/Aliexpress vendors. I thought the bracket opening was 90mm and the pin spacing was 90mm but I'm seeing those numbers +- 5mm. Maybe on the bracket opening, that's sorta ok, but the pin spacing has to be pretty exact. I'm guessing that all would probably work for a 1-1.8 ton excavator, but, geez, it shouldn't be that hard to have consistant numbers.
Any words of wisdom from you guys?
BTW, as a newbie, I really appreciate you folks as a resource.
New/Unused 20x30 All Steel Carport (A61166)
New/Unused 20x30...
New/Unused Pallet of 5 Binders and 10 Chains (A61166)
New/Unused Pallet...
2025 Kivel 42in Forks and Frame Skid Steer Attachment (A61567)
2025 Kivel 42in...
Dad's Garage Decorative Metal Sign (A61569)
Dad's Garage...
832779 (A61166)
832779 (A61166)
2023 CATERPILLAR 289D3 SKID STEER (A62129)
2023 CATERPILLAR...
