JD 410 loader tilt cylinder rebuild
/ JD 410 loader tilt cylinder rebuild #1
Garykk
Southern NM
Jd 4100 hst
It’s been a long time since I’ve been on this site. The old 410 has served me well but one of the tilt cylinders on the loader is now leaking. I rebuilt them many years ago but I’ll be darned if I remember how to take it apart. I know the bucket end unscrews but I think there’s a lock pin somehwere and my notes don’t show it. Any of you old timers out there remember how to do this?
/ JD 410 loader tilt cylinder rebuild #2
I used to have a JD4100 with 410 loader. I actually removed and reinstalled that cylinder. From what I remember the cylinder was easily removed with wrenches. Just jiggle the joystick a few times after shutting off the engine to release pressure.
Thanks but I need to know how to get the cylinder rod guide off the cylinder itself.
/ JD 410 loader tilt cylinder rebuild #4
Does it have the wire threaded in there to lock it?
/ JD 410 loader tilt cylinder rebuild #6
My mistake. Your photo shows it on the loader. I removed it and took it to a hydraulic shop.
I cleaned off that part, looks to be just a dimple. I’m pretty sure the rod guide just screws off with a spanner wrench and that dimple is a guide. I’ll find out in a few days when the weather gets a little warmer.
/ JD 410 loader tilt cylinder rebuild #8
/ JD 410 loader tilt cylinder rebuild #10
Here is video with lift cylinder wire involved.
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
1043 (A60430)
1043 (A60430)
2023 Kubota L6060HST Compact Utility Tractor (A61307)
2023 Kubota...
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
10' Container w/ Side Door (A60463)
10' Container w/...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
