JD 410 loader tilt cylinder rebuild
   / JD 410 loader tilt cylinder rebuild
I found an old thread on rebuilding the cylinder. Even had pics. Thread went back a few years🙄
Thanks everyone for replies
   / JD 410 loader tilt cylinder rebuild #12
Have the wire or have the snap ring? We'd like know, thanks
And slip in a link to that old thread.
Could not find the link again but I did have the download. The cylinder has a snap wire
  • JD460 Loader Cylinder.pdf
   / JD 410 loader tilt cylinder rebuild #14
Got it, thanks. Has the locking wire.
Well I finished the project. The guide in the cylinder is held in by a wire. Unfortunately I turned the guide the wrong way WhenI tried to remove it, that and I did not realize that the wire must be started outside the guide via the small notch in the guide.
To remove this type, the wire which has a small rise on it that sits in the notch on the guide. It must be pried out and then the guide turned clockwise and when inserting a new wire , the guide must be turned counter clockwise. The rest was pretty easy except for the two piece seal on the piston. The inner seal is just a large O ring that keeps the outer seal expanded. The new outer seal is made of a very stiff material and was a bear to not only get on the piston but the get it compressed enough to slide into the cylinder.
Thanks for all the suggestions and help, truly appreciate it.
Oh, and the wire comes not in a circle but straight and goes on very easily.
2019 Freightliner M2 106 AWD Terex Hi-Ranger TC55 55ft Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
2013 FORD F-350 (INOPERABLE) (A58214)
2013 FORD F-350...
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
2013 John Deere 27D Mini Excavator (A55973)
2013 John Deere...
DEUTZ MARATHON...
