JD 410 loader tilt cylinder rebuild
   / JD 410 loader tilt cylinder rebuild
I found an old thread on rebuilding the cylinder. Even had pics. Thread went back a few years🙄
Thanks everyone for replies
   / JD 410 loader tilt cylinder rebuild #12
Have the wire or have the snap ring? We'd like know, thanks
And slip in a link to that old thread.
Could not find the link again but I did have the download. The cylinder has a snap wire
  • JD460 Loader Cylinder.pdf
   / JD 410 loader tilt cylinder rebuild #14
Got it, thanks. Has the locking wire.
Well I finished the project. The guide in the cylinder is held in by a wire. Unfortunately I turned the guide the wrong way WhenI tried to remove it, that and I did not realize that the wire must be started outside the guide via the small notch in the guide.
To remove this type, the wire which has a small rise on it that sits in the notch on the guide. It must be pried out and then the guide turned clockwise and when inserting a new wire , the guide must be turned counter clockwise. The rest was pretty easy except for the two piece seal on the piston. The inner seal is just a large O ring that keeps the outer seal expanded. The new outer seal is made of a very stiff material and was a bear to not only get on the piston but the get it compressed enough to slide into the cylinder.
Thanks for all the suggestions and help, truly appreciate it.
Oh, and the wire comes not in a circle but straight and goes on very easily.
John Deere 5105M (A53317)
John Deere 5105M...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
20FT X 12FT LIVESTOCK METAL SHED (A58214)
20FT X 12FT...
Mini Skid-Steer 4-in-1 Bucket (New/Unused) (A59225)
Mini Skid-Steer...
1998 FREIGHTLINER FL50 SPORT CHASSIS (A56129)
1998 FREIGHTLINER...
2014 Bolens 11A-020W765 20in Push Mower (A55973)
2014 Bolens...
