GC2600 tachometer/squealing noise
   / GC2600 tachometer/squealing noise #33
Thanks and merry Christmas! Going to order one and try it out.
Ordered one today. Shipping was $15, so I went that route instead of going to the dealer. Dealer is a 3 hour round trip.
   / GC2600 tachometer/squealing noise #34
I got the new part yesterday. Just put it in now. Not sure how this will change anything, as it’s just a direct drive piece. Same as the one that came out. We’ll see once it gets cold again.
   / GC2600 tachometer/squealing noise #35
would be very interested in results.
   / GC2600 tachometer/squealing noise #36
I'd also be interested in the results. If it's an upgraded part and the cost is reasonable I'd fix mine. When this first happened I was told I would need a complete new tachometer. When I was given the cost, I told the parts guy, AGCO could put it where the sun don't shine.
   / GC2600 tachometer/squealing noise #37
Maybe I’ll go out and fire it up tomorrow. Supposed to be 19 degrees. If it’s going to make the noise, it will.
   / GC2600 tachometer/squealing noise #38
Well, it was 19 today. Felt colder than that. Fired it up and idled 5 minutes. Then up to 1650 for a few minutes, then back to idle for a few. 10 minutes in total and no noise! 😁 was definitely colder today than the last time when it made the noise and before I changed that part. The new piece had a lot of grease in it, which had to lube everything good. A very thin grease.
   / GC2600 tachometer/squealing noise #39
I notice mine mostly below 20 when its also been humid (snow/etc) out, dry air not so much. please update as you go, thanks.
   / GC2600 tachometer/squealing noise #40
Had to clear the driveway out today. 10 F outside. Blew out driveway with no squealing at all. So far so good with this new part.
2008 DOOSAN G25 GENERATOR (A58214)
2008 DOOSAN G25...
(APPROX. 20) 4' X...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58216)
30 INCH TOOTHLESS...
2014 Toro Groundsmaster 4500D 5- Deck 4WD Rotary Commercial Mower (A56857)
2014 Toro...
23105 (A56859)
23105 (A56859)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
