Help identifying PTO shaft profile
/ Help identifying PTO shaft profile #1
rlrobinhood
Chester, MT
Kubota L4200
Hi all,
I just bought a used three-point snow blower and it is missing half of the PTO shaft (tractor side). Can anyone tell me if this takes a square/rectangle shaft? Or is it something else? I believe the squared off dimensions are 1 1/8" x 1 3/16". I've never seen the channels before on a PTO shaft, but then again, all my equipment is VERY old.
Thanks all and happy Thanksgiving!!
/ Help identifying PTO shaft profile #2
I'd just use a square on that fits. The dimensions sound right for it. Not sure on the "extra" grooves.
/ Help identifying PTO shaft profile #3
It would be more accurate if you can look at the other end (deep in the hole) as it would not be worn. They may have had a rectangle to keep the u-joints in phase. :unsure:
/ Help identifying PTO shaft profile #4
It's getting a bit harder to find the square pto shafts, the reason for the slots was to allow a small bolt or screw to be used to "clock" the shaft for the ujoint alignment.
/ Help identifying PTO shaft profile #8
I think that's it! 35 Series. thank you. Boy, Weasler parts are expensive. It seems the 35 series is proprietary to them.... just my luck.
The 35 series is an old Rockwell series of driveline. Weasler is just one of the few companies that supports the really old stuff. Its far from proprietary, just ancient.
/ Help identifying PTO shaft profile #9
/ Help identifying PTO shaft profile #10
/ Help identifying PTO shaft profile #11
Hi um, there are more than 1 series that uses square/rectangle shafting. The easiest way to determine if it's 35 series, is measure cap size of u-joint. If it's 1-1/4" , with old school pinch snap rings and not with holes , and square profile you are on the right track. I use a book that has them in order, and check more than one measurement to be sure. 35R is indeed quite common regardless
Thanks Rod. I now have it all squared away. 35 series it was. Have a great week all!
2025 LandHonor MPF-11-2000G Fork Frame Skid Steer Attachment (A60353)
2025 LandHonor...
207273 (A52708)
207273 (A52708)
2025 GIYI GY-P45 Hydraulic Breaker Skid Steer Attachment (A61567)
2025 GIYI GY-P45...
Case IH 315 Magnum (A62177)
Case IH 315 Magnum...
2008 FORD F350 XL SUPER DUTY DUMP TRUCK (A62130)
2008 FORD F350 XL...
2021 VOLVO VNL860 6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2021 VOLVO VNL860...
