Help identifying PTO shaft profile
   / Help identifying PTO shaft profile #1
rlrobinhood
Chester, MT
Kubota L4200
Hi all,
I just bought a used three-point snow blower and it is missing half of the PTO shaft (tractor side). Can anyone tell me if this takes a square/rectangle shaft? Or is it something else? I believe the squared off dimensions are 1 1/8" x 1 3/16". I've never seen the channels before on a PTO shaft, but then again, all my equipment is VERY old.
Thanks all and happy Thanksgiving!!
   / Help identifying PTO shaft profile #2
I'd just use a square on that fits. The dimensions sound right for it. Not sure on the "extra" grooves.
   / Help identifying PTO shaft profile #3
It would be more accurate if you can look at the other end (deep in the hole) as it would not be worn. They may have had a rectangle to keep the u-joints in phase. :unsure:
   / Help identifying PTO shaft profile #4
It's getting a bit harder to find the square pto shafts, the reason for the slots was to allow a small bolt or screw to be used to "clock" the shaft for the ujoint alignment.
   / Help identifying PTO shaft profile #8
I think that's it! 35 Series. thank you. Boy, Weasler parts are expensive. It seems the 35 series is proprietary to them.... just my luck.
The 35 series is an old Rockwell series of driveline. Weasler is just one of the few companies that supports the really old stuff. Its far from proprietary, just ancient.
   / Help identifying PTO shaft profile #9
   / Help identifying PTO shaft profile #10
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2016 POLARIS RAZOR XP1000 (A51222)
2016 POLARIS RAZOR...
2019 CATERPILLAR 326FL EXCAVATOR (A51242)
2019 CATERPILLAR...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2014 New Holland T8.360 MFWD Tractor (A52128)
2014 New Holland...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
