Check transmission / hydraulic fluid level YM 3110D
/ Check transmission / hydraulic fluid level YM 3110D #1
AndyTheCornbread
NW Montana
Yanmar 3110D, IH Hydro 86
I guess I have three questions:
What gear and shuttle shift position should it be in when I check fluid?
Should it be running or not running when I check the fluid level?
If running, at what RPM?
/ Check transmission / hydraulic fluid level YM 3110D #4
Fluid should be clear oil almost transparent. Definitely not milky or foamy.
Photo shows Tractor Supply's UTF swapped out after 10 years in the YM240 (simple gear transmission, not Powershift). Nothing has settled out in the couple of years that I've saved this sample, the text I set it on isn't obscured. Looks to me that this could have been left in service even longer. But only for a gear transmission. Powershift deserves more frequent fresh fluid.
20220521_153809-jpg.747085
/ Check transmission / hydraulic fluid level YM 3110D #5
The Hyd. YM2000 pan looked like a Vanilla milk shake. The Bottom was as thick as Crisco in a can. had to scrape it out though the Filter tube.I'm in the high 900 tac. Hrs. so it's due to get changed again. This time I hope that's what it looks like! Pretty sure it will.
Deere 333E (A60462)
Deere 333E (A60462)
2016 Yanmar VIO25 (A60462)
2016 Yanmar VIO25...
2019 Ram 2500 4x4 Crew Cab Pickup Truck (A60352)
2019 Ram 2500 4x4...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
1000 Gallon Nurse Tank (A60463)
1000 Gallon Nurse...
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
