attachment for cleaning/creating drainage ditches along gravel road
/ attachment for cleaning/creating drainage ditches along gravel road #1
rider89
Kubota B7500
We have a small subdivision with gravel roads and want to do our own maintenance on the drainage ditches. The local outfit that does the main grading of the road does fairly well with crown, but very poor on the drainage (intentional?), causing extra work after big rains. I'd like to be able to reach past the shoulder about 2 feet and a 25° down angle, and be able to move the matl up on the road, or swivel the blade to move the matl away from the road. We wouldn't be cutting undisturbed dirt, just cleaning existing ditches that have washed out into poor shapes that clog easily. Not sure if our tractor (New Holland 1920) is heavy enough to pull the blade off the 3pt hitch. A tow behind rig may be better? We don't need to do planing or crowning with it. Any ideas? LandPride RBT60 series gets close as far as the 3pt mounting type, but only tilts 15°
/ attachment for cleaning/creating drainage ditches along gravel road #2
I clean and grade my ditches. I have a mile long gravel driveway. My Kubota M6040 with grapple and rear blade weighs a tad over 10,000 pounds.
My first tractor - Ford 1700 4WD - did an adequate job of clearing and regrading the driveway ditches. I had a 450 pound Land Pride rear blade then.
Your 1920 NH is the same as a Ford 1920 and weighs around 3000 pounds. With that front weight and being 4WD it should do the job for you. Now to find a rear blade that will tilt 25 degrees.
If you plan on clearing snow with the rear blade - offset, angle and tilt are a real benefit. Honestly - if a rear blade has tilt - more than likely it will also have offset and angle.
/ attachment for cleaning/creating drainage ditches along gravel road #3
Pictures always helpful.
Is there a reason you aren't grading the road yourself so the drains don't get messed up?
/ attachment for cleaning/creating drainage ditches along gravel road #5
So, I use a Tufline 6 footer grader blade ($250) which can offset to the side and angle/tilt down. With my hydraulic top and (especially) the side tilt, I can get a pretty aggressive cut for my ditches. I also can only cut by following my rear tire. I can not cut a ditch from the top surface of the road... that would have too much leverage and it would just drag your front tires over (into the ditch).
I don't see any hydraulics on your tractor so you might be limited in what you can do.
You don't have have your location listed in your profile... If this is close to you, I would jump on it. https://jxn.craigslist.org/grd/d/pittsford-tufline-7ft-grader-blade/7799800568.html
Tufline 7Ft Grader Blade - $1,000 (Osseo MI) Might not last long but here's a couple photos:
/ attachment for cleaning/creating drainage ditches along gravel road #6
I can tilt angle and offset my back blade, it will dig a good ditch in doing so. However any rocks or roots will pull the tractor around quite a bit.
/ attachment for cleaning/creating drainage ditches along gravel road #7
Do it the old way.
That's doing it the right way! Not just for a roadside ditch, but one of the photos seems to be cleaning or creating an irrigation canal. We all need something like that!
Here's ballast added to the end of a light blade to improve the lane crown. I have three more of these 77 lb weights I could add for a deeper cut. As shown here, tilting the 3-point fittings did essentially nothing with such a light blade before I added the ballast.
img-20210322-01rbackbladeinlane-jpg.699999
I have a
I like the idea of a towable since our tractor probably isn't heavy enough to pull several feet of offset on a 3pt rear blade. Have you ever seen a modern version of this Martin unit being sold?
/ attachment for cleaning/creating drainage ditches along gravel road #9
organizational factors, hoa board, etc. Some new members of the board finally willing to get equipped for it.
/ attachment for cleaning/creating drainage ditches along gravel road #11
Say, your Tufline looks like our similar vintage 8 foot "Big Rhino". Anyone considering one should keep in mind that these big old 3-way blades needs a larger tractor when offset with a tilt & angle. A rear blade for ditches and crowns needs to be 3-way adjustable: offset, tilt, and angle.
Gotta wonder what a new 3-way Tufline would cost today? I suspect that $1000 for a used one is a steal. Those big 3 way blades used to be offered as manual adjustable for economy, which could be later be converted to hydraulic control with simple kits.
I'd try to borrow or rent one before buying it. Too much depends on the OP's ditch material and such to tell if his tractor would pull it. We use a 6000# long wheelbase tractor with a Cat. II 3pt. with the Big Rhino blade.
Even so, any tough spot pulls the tractor sideways pretty easily. After using our blade for years, my opinion is it can be made to work, but I'm not convinced that even a good 3-way blade is the right tool for the job. For one thing a blade hung out like that from the back end of a tractor pitchs up and down a lot. Maybe a gauge wheel would help....but there's another hydraulic and another grand or two.
OP might also look into the smaller road graders. Smaller used ones are pretty reasonable at municipal sales. Around here anything a municipality bought with tax dollars has to be offered to the public when they upgrade. There just isn't much of a used market for graders - worth a look.
A grader is a much better machine for shaping roads and ditches than anything pulled by a tractor can ever be.
YMMV,
rScotty
/ attachment for cleaning/creating drainage ditches along gravel road #12
...Gotta wonder what a new 3-way Tufline would cost today? I suspect that $1000 for a used one is a steal....
Found some prices (link above) Yes, a grand for the one on Craig's list is a bargain.
The one I bought for $250 is $2400-ish. I only use it for cutting ditches which can only be done heading downhill... It puts me on a pretty steep side angle after a couple of passes but works like a charm!!!
/ attachment for cleaning/creating drainage ditches along gravel road #13
Big Rhino 3-way & Little Rhino 3-way.
/ attachment for cleaning/creating drainage ditches along gravel road #14
About 15 years ago DW and I were out driving around and she spotted one of these old Ford 6' grader blades with horizontal swivel and vertical tilt leaning against a tree with a for sale sign.
I can set it so it acts like a double-shovel plow and dig a pretty good ditch.
Mine is in better condition than this picture.
If anyone wants, tomorrow I can go snap a picture of the nameplate and edit this post.
This one is swivel and tilt, and for sale: https://www.schneiderauctioneers.com/auctions/30324/lot/14856
/ attachment for cleaning/creating drainage ditches along gravel road #15
I run a Tufline GB1 7 foot.
Here in VT, It's too rocky to do much without tearing stuff up.
But it moves soil, and gravel just fine behind my 35 HP tractor. The ditches on the side of the 500 foot long, steep incline drive, are ledge and bony fill. Hard to do much with it.
Your conditions may differ.
A back blade with tilt and offset is the tool, even if it takes a bunch of passes and some hand work.
/ attachment for cleaning/creating drainage ditches along gravel road #16
A 10 ton mini-x with a ditching bucket and wrist does a nice job. Add a rotator and you will really have fun.
/ attachment for cleaning/creating drainage ditches along gravel road #17
That's the same thing I have and I agree you have to be careful where you use it in our bony ground. But just cleaning loose stuff out off an already formed ditch works OK for me.
gg
/ attachment for cleaning/creating drainage ditches along gravel road #18
I use an 8' York rake and T&T kit which gives the blade a 15 degree pitch.
I offset the 3pt as far as I can and it does a good job on the ditches.
The only downside is, dragging the spoils back up onto the road requires regrading the surface. The mud & grass can make quite a mess.
My old Kubota L3430 had no trouble pulling the rake, but I don't know how well it would work on a smaller tractor.
/ attachment for cleaning/creating drainage ditches along gravel road #19
I'm in the same boat as you - Everything Attachments "Extreme Duty" 5' offset adjustable landscape rake off the back of a BX2360 working clay soils.
It does the job just fine... actually can dig deeper than I would have expected given the size of the tractor pulling it, and depending on the geometry of the ditch being created/maintained.
Downsides which apply to everyone to some extent or another - soil condition, especially dry clay can really hamper the ability to move material. There are times I've had to break out a subsoiler to loosen things up prior to using the landscape rake for ditching/contouring.
The bigger issue is of safety and being aware enough and moving slow enough that if the rake/blade catches a well embedded rock to stop before something breaks or the tractor starts pivoting around the rock.
One of these years after the kids are grown I'll be able to afford a set of gauge wheels. I'd imagine those are the bees knees for crowning.
/ attachment for cleaning/creating drainage ditches along gravel road #20
Rear blades are rare and expensive in the south where you don't have everyone pushing snow. I have a dirt road that runs alongside my rental property and as the road gets rougher, people tend to drive up on the side of the shoulder where it is smoother. The ditch just fills with sand because of the same reason.
I have considered taking a 30" rear pond scoop (dirt scoop) and either modifying the bucket or building a new one. Basically the new one would have the back side of the bucket opened up on one side so it would channel the dirt back onto the roadway so I didn't have to pick it up and dump it on the road. Once the modified pond scoop was pulled thru the ditch, I could come back with my rear landplane or box blade and level the dirt across the many potholes in the road.
This poor ole roadway has been neglected for many, many years with only a couple of the residents ever doing anything, and most of those are simply way too little, way too late.
David from jax
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2008 MACK CHU613 DUMP TRUCK (A60736)
2008 MACK CHU613...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
FOUR WAY BLADE SKID STEER ATTACHMENT (A58214)
FOUR WAY BLADE...
2012 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2012 DRAGON 150...
