I recommend a tractor rake to collect and remove roots and stones from the ground
   / I recommend a tractor rake to collect and remove roots and stones from the ground #1
hybris
Member
italia
SAME Minitaurus 60 dt
hello, I should reclaim a land that has been uncultivated for years, I should eradicate the weeds, the invasive vegetation of the small shrubs such as ailantos that have created a grove and free the uncultivated and invaded area from vegetation to create a clearing. I would like to attach to my tractor a sort of large and sturdy rake to eradicate and pile up in sheaves these waste materials. some ideas perhaps by building a tool similar to a large rake or a pitchfork with sturdy teeth and prongs that by sinking into the ground and making the tractor advance, tear out the weeds, roots and emerging stones thanks
.the land is on a non-flat hill with the presence of alluvial sediments, river stones and clay. it is material brought back from earthmoving works such as an abandoned landfill where time has created a sort of jungle thanks to
   / I recommend a tractor rake to collect and remove roots and stones from the ground #2
If you have a box blade they generally have some pretty sturdy rippers to dig into the earth.
Io sono italiano, non capisco a quale attrezzo ti riferisci, il trattore può essere dotato di una fresa a zappe rotanti, non so come la chiami, mi servirebbe qualcosa tipo uno scarificatore con delle ancore robuste, l'aratro rivolta il terreno, mi servirebbe anche un attrezzo frontale che estragga le radici e poi le raccolga e le ammucchi in covoni, non so come la chiami grazie
Rastrello Tactor fai da te
Vorrei realizzare una forca rastrello per rastrellare il terreno in questo modo. Puoi aiutarmi? Grazie.
   / I recommend a tractor rake to collect and remove roots and stones from the ground #5
squartatore?
   / I recommend a tractor rake to collect and remove roots and stones from the ground #7
squartatore?
[traduttore Google]
Questo accessorio serve per scavare in profondità senza rivoltare il terreno: serve a migliorare il drenaggio e ad allentare il terreno profondamente compatto.
Hai già pesi extra per il trattore e eventuali accessori?
   / I recommend a tractor rake to collect and remove roots and stones from the ground #8
Folks, he's got land that's been uncultivated for years.
It has a lot of weeds, with invasive small shrubs (possibly tree of heaven).
He wants to create a clearing.
Sounds like he's considering rippers, but generally is looking to remove the weeds / roots, and rocks - sounds like it's an old landfill site that was filled in with river sediment (stones & clay).
Looks like he's got a "SAME Minitaurus 60" tractor -- 80's 59hp, possibly 4wd, ~5000# bare weight.
yes the land has been abandoned for years, there are bushes, canes, ailantos, spontaneous trees. I have done the cutting work, now I have to free the ground from stones and roots, the ground was sunken and they filled it with soil resulting from excavation and earthmoving work. clearly it is a landfill, maybe I should rent a large earthmoving machine to level and compact the earth and break up the surface layer with the teeth, so it can trace the paths and the access ramp. maybe an excavator or a large mechanical shovel right? then I will do the finishing work with my old same thanks
2004 FORD F-350 XL DUALLY CREW CAB FLATBED TRUCK (A59823)
2004 FORD F-350 XL...
2017 CAT 315F LCR EXCAVATOR (A58214)
2017 CAT 315F LCR...
2015 Ford Escape AWD SUV (A59231)
2015 Ford Escape...
2020 Kinze 3505 High Speed 6/11 Planter (A56438)
2020 Kinze 3505...
2024 Spartan SRT-XD Zero Turn Mower (A59814)
2024 Spartan...
KUBOTA M125X TRACTOR (A60430)
KUBOTA M125X...
