Blackberry Removal
/ Blackberry Removal #41
If you wanna kill big leaf maples cut them off. Bore the stump with the nose of your chainsaw or use a big drill bit.Pouring straight glyosphate might do the trick but something like Garlon Tordon, etc nasty stuff will kill it. Gotta do it when the stump is fresh.
But the best place to pour the Tordon is around the outer edge - at the growth ring. The middle does not matter. You want to apply it within 15 minutes of cutting because the tree will try to protect itself by closing those pores that got cut.
/ Blackberry Removal #42
I think even more effective are near-vertical hatchet cuts around the trunk. Peel back an outer layer flap and dribble Roundup or whatever right into the growth layer.
/ Blackberry Removal #43
We had a serious blackberry problem and even worse were the rabbits that had their burrows amongst the black berries we tried every thing including deep rotary howing after mowing used round up an several other brands with limited sucess, then one day the damage the rabbits did to our blue berry seedlings about 500 in a rabbit proof fenced off area they found a spot where the wire was not as deep in the ground and got in .
We got the oxy acetaline on the carry all blocked off all the rabbit burrows we could see and proceeded to fill the burrows with a mix of oxy acettaline lit a short bit of fuse and the whole 50 ft diameter blackburry patch lifted about 2ft in to the air no more rabbits in that patch, then give it another hit with round up that killed it then we pushed it up into a pile on the same ground and burned it, Did that to the other blackberry patches never had a problem again, the explosion airrated the ground made it easy to push in to a pile roots and all
I think burning them on the spot instead of picking them up stopped the spread.
This block was cleared neglected dairy pastures that were broken up and sold as 30 acre lots
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
2024 MACK GRANITE GR46F DUMP TRUCK (A59823)
2024 MACK GRANITE...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Kia Forte Sedan (A59231)
2018 Kia Forte...
2019 Ford F-550 4x4 ETC37IH 37ft Insulated Bucket Truck (A59230)
2019 Ford F-550...
