For those with block heaters
/ For those with block heaters #41
My cab M9 came with a block heater in one of the freeze plugs and I've never used it and it gets cold here. No matter how cold it is in the barn, 15 seconds on the glo plugs and 1/2 a crank and it's running. I'm just south of Detroit or 60 miles from Canada.
/ For those with block heaters #42
I would think that time on, on a block heater would depend on the size of the heater more than anything else. I think the one in my M9 block is 1000 watts, I think.
/ For those with block heaters #43
As an aside, I've never used it and never planned on using it and it gets REAL cold here. I always make sure my starting batteries are fully charged 9and I change starting batteries every 3 years or sooner if they act like they are getting weak (I load test them). I run 5-40 Rotella T6 year around and when the tractors are in the barn, I isolate the starting batteries with a positive isolator and close the circuit just prior to energizing the glo plugs.
People get concerned about stone cold diesels banging and clanging when cold. All that is, is the sound of incomplete combustion and in no way impacts the engine. So long as you have oil pressure, all is good and I don't rev them up either. I let them idle until they start to warm up and then go about my business which is most times enough time to have a hot cup of coffee.
Been doing that for years now so no need to spin an electric meter with a block heater. Just because the block is warm (block heater) don't mean squat for the hydraulic oil anyway so what I do works fine and has for years.
Diesels are compression ignition so compression ignition always makes some noise anyway. Cold compression ignition just produces more noise. Nothing to worry about. Long as there is oil pressure, all is good.
If you really want to hear compression ignition, find a Cat 1693 and listen to one. They got the nickname 'Clatterpillar' because they make terrible compression ignition noise. All pre chamber diesels rattle to some extent and most all tractors are pre chamber engines.
/ For those with block heaters #44
I like block heaters on any engine that is going to be used in cold weather. I feel it is easier on the engine, even ones that will start without one. Most of the larger more expensive equipment that is setup for cold weather will have engine and many times transmission/hydraulic heaters. Even if they will start without it why be that mean to a piece of equipment.
One thing to be aware of is that some engines with temperature sensitive pre heat controls may not run the manifold heat long enough in very cold temperatures.
I have seen a few engines that would fire and the cold air would snuff the fire out in -20F weather, not nice to have happen as often that first start has taken enough of toll on the battery that more time on the pre heater and the engine now cranks too slow to fire. Not a fun way to start out.
/ For those with block heaters #45
SF Bay Area and the Cumins Diesel hospital generator coolant heaters are on 24/7 to maintain 180F for instant start and load transfer a few seconds later...
It makes a noticable difference on how smooth it starts compared to no heater.
Should the heater fail there are 2 alarm panels inside plus one on the generator to let me know low coolant temp.
/ For those with block heaters #46
I put a block heater in my Massey GC2410. I’ve only used it 5 or 6 times when I had to blow snow when it was in the single digits. I have a cord that runs to the tractor shed from the garage. The night before a storm, I’ll hook up the heater to the cord. Usually I’ll go out to the garage and plug it in for 45 minutes and just piddle around until the time is up. Then head back to the shed and fire it up. Works great and saves the battery from excessive glow plug cycling and long cranking times. The battery in the tractor is undersized IMO.
/ For those with block heaters #47
If you can, depending on the heater, an hour or two is all it should take. In my situation, I plug the tractor in when I am done, unplug when I need to use it. Mostly every day, but sometimes up to 4 days between. The cost is miniscule, but having a warmish tractor at my disposal is priceless. Feeding my animals is every 5 days unless it is getting really cold. But I feed the neighbors animals, so it is when they call. The tractor is ready to go. With snow falls between, I may have to plow after work, and the tractor may run every day. Ideally an hour before you need it with sufficient warm up should be fine above 0°F, 2 hours below 0°F.
/ For those with block heaters #48
It gets fairly chilly here in the winter months, and out of the diesels I have owned: 2001 6.6, 2016 Colorado 2.8, and 2020 Silverado 3.0, I would say none of them (when properly running) ever required the block heater to start the engine. The 2001 had a time when only one glow plug was working, and that stint did require the block heater to compensate in the cold. On the coldest of nights I do sometimes plug in just in case, and it feels like it is a more graceful start when I do. I plug in before i go to bed - 8pm-10pm, and start up around 4am, so it stays plugged in for 6-8 hours.
For the current tractor JD 3039R, i always plug in if i leave it out overnight, or for the entire day - no idea whether it is necessary or not. My old JD 770 did not have a block heater, so I relied on glow plugs only, and I did have one time where stored in a not quite weather tight un-insulated garage, and it did not want to start and run on all 3 cylinders.
/ For those with block heaters #49
SF Bay area, does it even sell #1 Diesel in that area?
Back when I worked at a Ford New Holland Dealer, twisting wrenches, we would always recieve a New Holland Shippment, in January, usually the coldest day in January. We would get a heads up 3-5 hours before they would get there, so we could get a Tractor/Loader started and running. Hydraulic Oil moving.
The Transports would die, just idling outside while we unloaded the trailers. Fuel Gelled up, and they were only coming from Kanas on #2 Fuel.
Up here, many Bush Worker, won't even start their machines in -25-30 below, They will start, but Metal is so brittle that it will break
/ For those with block heaters #50
I am way up north about 30 miles from the Canadian border. Clearing snow in the winter is one of the primary tasks for my diesel tractor (JD 4120 that I bought new in 2005). A block heater was the only option I added to it at purchase. I wouldn’t dream of starting a diesel engine on any machine up here in winter regularly without a block heater.
How long I energize it depends on the outside temperature. 1/2 hour is good between 25 and 55 deg F. If it’s colder than that, I’ll let it go for an hour.
I keep the tractor under a porch on the barn that I can see from the house. The block heater is plugged into a heavy gauge extension cord, which is plugged into an outlet that is switched inside my house.
There is also a light on the front of a boat bar in the house that is plugged into that outlet. I know the block heater is on when that light is on.
If it snows overnight, I’ll flip that switch as soon as I wake up in the morning. If it snows while I’m at work 30 minutes away, I’ll call the wife or kids and have them flip it when I start my drive home.
If you’ve ever had the chance to listen to a diesel engine start in cold weather with and without a block heater, you’d quickly gain an appreciation for the damage that is done to the engine by not using it. Mine sounds just like it does in the middle of July, in the middle of January, when I use the block heater.
/ For those with block heaters #51
An engine will likely appreciate being kept warm but a continually run block heater can bump the power bill a bit.
The small block heaters are normally 400 watt heaters the larger 800 and a few 1000 watt units.
If your power is $0.20 per kwh running a heater for 24 hours a day adds up.
400 watts = 0.400 kwatt x $0.20 x 24hrs = $ 1.92 per day or over $57 per month.
800 watt heat over $114 per month and then the killer the 1000 watt heaters,
$4.80 a day or $144 a month.
I have had decent luck with the smart switches (wifi) to control block heaters, the ones I have used do not have a outside temperature input but they have considerable programming ability for times on/off as well as remotely being turned on via a smart phone app.
I like the idea of a light to know when it is on or off. The timer I have has 2 outlets. I'll have to rig something up.
/ For those with block heaters #53
I'd sure like to see an actual link that states starting a cold diesel engine with no block heater damages it.
I don't believe there is one but could be wrong and I want a link from someone that is a professional, not some amateur person.
I don't think there is one actually. Like I said previously, the rattle you hear is actually incomplete combustion in a pre chamber engine and so long as there is adequate oil pressure no damage is done and never will be. Conversely, the hydraulic oil is still cold which is why I warm up my units prior to moving them in cold temps. You'll do way more damage internally with stone cold hydraulic fluid than you'll ever do with a cold start engine.
Bring on the substantiative link if there is one....
/ For those with block heaters #54
I only heat my block when I know I’m going to use the tractor. Been doing it that way for over 30 years.
When to energize is dependent on what time the storm is expected.
If I’ve forgotten 4 hours is more than enough to prevent beating on the battery but cold starting will work.
/ For those with block heaters #55
Even gasoline engines can benefit from a block heater in really cold weather. My snowmobile starts a lot better using one. Such a small engine (aluminum) that it only takes a half hour or so.
I bought one of those magnetic pan heaters for my tractor not realizing the pan was non-ferrous. :oops: I'll use the old school trick of a droplight with a 100W bulb in the engine compartment if I'm going to need the tractor and it's going to get below 20 or so.
There's nothing I need to do that has to be done in -20 temperatures.
Block or inline coolant heaters seem to be standard equipment on most, if not all commercial generators I've had to deal with.
/ For those with block heaters #56
This question is a really good way to find out who is connected to the grid ;)
Seriously though, I've heard many times about folk who complain about block heaters failing. It doesn't matter the style: hose, frost plug, etc. But I believe the failures tend toward those who plug them in and leave them powered. Especially with undersized or over length extension cords with receptacles and plugs in poor condition. Or the heater is a much higher wattage than is really needed and still left powered.
/ For those with block heaters #57
When it’s below zero I’m pretty sure my tractor with a 3 cylinder 55 horsepower Yanmar engine wouldn’t start without having the block heater plugged in for an hour or so even though it’s parked inside a non heated building, if it’s really cold like -20 I sometimes plug it in for 3-4 hours.
Yes I have operated diesel engines that start very easily when it’s -20 without being plugged in but my 3 cylinder Yanmar ain’t like that. I ain’t never had a no start situation but I believe that’s because I plug it in when it’s cold out.
/ For those with block heaters #58
My tractor stays in my heated garage, but if I had it stored outside in the cold, I’d definitely use a cheap timer with the block heater, so you don’t waste electricity through the entire night.
You can get outdoor rated timers on Amazon for $13. Would pay for itself in short time
/ For those with block heaters #59
Voltage drop due to cord length or plug condition can only INCREASE a resistance heater's expected life time.
/ For those with block heaters #60
From what I recall over the years the easiest way to have a block heater fail quickly is to start and run the engine with them still plugged in.
2020 23 Ft. Godfrey Marine Hurricane Boat with 26ft T/A Boat Trailer . (A64557)
2020 23 Ft...
215603 (A63276)
215603 (A63276)
2016 Chevrolet Silverado 1500 Pickup Truck, VIN # 1GCNKNEC1GZ163679 (A65563)
2016 Chevrolet...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
2018 FREIGHTLINER M2106 DUMP TRUCK (A63276)
2018 FREIGHTLINER...
2015 Audi A4 AWD Sedan (A64557)
2015 Audi A4 AWD...
